A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ahoeben 1,886
You don’t have to set them all. If you set the “main” one all the others change with it (unless you set a value for a feature-specific setting).
You don’t need to set anything in the start gcode; the plugin will handle that for you.
