I strongly recomend the brim feature for that part as otherwise the shrinkage may pull the corners off the print bed. Also use gluestick *and* heat the bed to 50C.
But if you use too much brim it will be too big to print so just do 2 passes of brim.
Or better - modify your model to have a 5mm wide, .2mm tall (thick) brim on the *inside* of the square in addition to 2mm brim on the outside.
Daid 303
This is because of the skirt, you'll have to disable the skirt (in expert settings) to get the full size, else it takes in account that the skirt has to fit on the platform.
