Thanks, so yeah changing to another material (A PLA that I have added) repopulated the profiles in the dropdown menu, I now see that when I select other materials that I have added such as ST-PLA or PLA+ they are highlighted in orange when selected from the dropdown list. Is this simply happening because I have effectively created a new unrecognised material by adding them as ST-PLA & PLA+?
How would I go about fixing this? should I simply re list these materials as PLA?
Another thing I notice is that Cura seems to lock up for 5-10 seconds every time I either change between materials or print profiles, any idea what may cause this?
nallath 876
No worries, you didn't lose all your work. The not supported thing is added if your machine says it has quality profiles per variant / material, but it can't actually find one.
So could you try switching material and / or nozzle?
If that still doesn't work, could you share your configuration folder with me?
