No it does not. I have removed/re-installed Cura, made the settings visible/hidden several times, restart Cura, not to mention expand/compress the settings sub-section. it just does not show up.
I found out why skin overlap wasn't showing. Well, not why exactly but . . . In the Shell section of the settings window, if I have top/bottom pattern set to Concentric, the skin overlap disappears. Change top/bottom pattern to either lines or zigzag, skin overlap re-appears.
- 3 weeks later...
Thanks for that... I was about to give up...
I'm still having problems with some settings that just disappear and just will not display. Latest example - Print temperature and print temperature initial layer. I tried everything I could think of and finally wound up recreating the profile.
burtoogle 510
Does closing and then opening the setting sub-section help?
