Cura 4.4 upgarde and Fusion 360
OriginalGriff
Posted · Cura 4.4 upgarde and Fusion 360
I just upgraded to 4.4 from 4.3, and the installation automatically uninstalled the old version - so far so good.
But ... when I try to 3D print from Fusion 360, the CURA selection no longer works.
A quick check in the registry shows that STL files are still linked to 4.3 (see image attached)
I can get round it by selecting "Custom" in F360, and pointing at the app manually, but it's not a "smooth" as it was (see image attached)
    Posted (edited) · Cura 4.4 upgarde and Fusion 360
    I can confirm this too. There is a class below called stl.4.4 in the registry. That is is wrong.
    You can do a workaround with an new/updated custom entry in Fusion 360 and choose then C:\Program Files\Ultimaker Cura 4.4\Cura.exe
    Not elegant but is works for the time being. Seems, we need to wait for a new update.
    Edited by DivingDuck
