Yes, indeed... thanx for your quick response!
However, this should not always be necessary.
The model I'm trying to print is an upside down cone shape.
At the top it has a diameter of 210mm, but at the bottom a diameter of only 70mm.
So plenty of room for a brim or skirt.
Cura should actually only use dimensions of the first layer to calculate the necessary space for brim or skirt.
Instead, cura uses the overall dimensions...
FYI: the reason why I print this upside down, is because it's printed in vase mode and will be used as a lamp shade
Thanks again for your response!
Peter
ahoeben 1,657
Cura accounts for space required by a brim or skirt. If you set the buildplate adhesion type to "None", you can use more of your buildplate.
