bob-hepple 59
Tinkergnome
as always thank you for your reply, can I ask the firmware version I'm running is 17.09. I checked your GitHub Mark2 Page and you have version 19.03 is it worth upgrading to this, and if I do would I have to recalibrate the Mk2,, also I have a menu option of Prime / Wipe position and it was set at X 105.00 Y27.00 which I changed as a test to X111.00 Y87.00 which might of helped, or am I just kidding myself?? but do I need this option??
tinkergnome 922
Cura always adds a (superfluous) move to the last x/y position of the previous extruder. You can't see it in gcode preview, because it's the exact same position where the previous move ended - but it's definitely in the gcode file.
In former versions of Cura this was the case on every tool change - so i appreciate it as an improvement that it only happens on the first layer... 😊
One could probably get rid of it with a post-processing script (like in the good ol' days...), but this needs someone who knows how Cura internally works nowadays... 🤷♂️
