If you select the main tab for extruder 2, what's the value for build plate adhesion extruder there? If it's extruder 2, that might be the culprit; change to extruder 1.
I believe this change has a good reason for it. I also find it surprising and annoying but I ignore it and the printer is able to print the part just fine. So maybe there is a good reason for it?
Enigma_M4 119
Hi aag,
Regards
