No. I'll try it. Thanks
Please save the project (File -> Save) and then attach the .3mf file to this thread. Perhaps if we can see the model and settings then we can suggest further remedies.
Attached
Thanks for the file. When I slice this, I don't see a large diagonal travel move over the skin. Could you please also attach the gcode that has the problem. Thanks.
Thanks for taking the time to look at the file. I've attached the gcode for this project.
When I slice the file the base is printed in 2 layers. The lower layer is printed vertically and comes out very smooth. The second layer though is printed diagonally and is very rough. If I make the base thinner it prints the first layer diagonally. Also, If I increase the thickness of the base so that it prints 3 layers, the lower layer is printed vertically and the 2nd and 3rd layers are both printed diagonally.
burtoogle 506
Have you tried setting combing to "no skin" ? That should help keep travels away from flat areas.
