Internal Geometry Missing
JHBP
Posted · Internal Geometry Missing
I have just tried the standard profiles "Normal" and "Fine" and they do not have the issue 😞 That means one of my custom settings is breaking it. I guess I can start over with "Fine" as a base, and change one thing at a time and see what breaks it?
    Yes... I was able to reproduce the problem! It is one of these settings. I don't really want to slice with one at a time 😞 Anyone know?
    conical_overhang_angle = 45
    conical_overhang_enabled = True
    gradual_infill_steps = 4
    material_flow = 107
    material_print_temperature = 215
    retract_at_layer_change = True
    retraction_amount = 7
    retraction_extrusion_window = 7
    small_feature_max_length = 7
    wall_line_count = 4
    wall_overhang_angle = 45
    wall_overhang_speed_factor = 50
