Ι used 0.2 height layer 30mm/sec speed. 0.4 nozzle olson.
- 4 weeks later...
I just printed small stuff until now, but I use 0.2mm layers, a 0.4mm Olsson Ruby nozzle on my Ultimaker 2+. Temperatures are 260°C nozzle and 65°C buildplate printing rather slow with 30mm/s and low cooling fan settings. Some gluestick works fine for adhesion.
Some °C more on the nozzle would be good I think, but the 2+ doesn't allow more than 260°C.
Overall these settings work fine for me.
Carla_Birch 115
With filaments like carbon fills and wood files, its better to use a nozzle thats a min of 0.5 to stop the nozzle from blocking easy, its why Ultimaker's high wear nozzle is a 0.6.
Edited by Carla_Birch
P3D 46
Hi, what nozzle diameter are you using? What diameter does colorfabb recommend? Also, at what layer height were you printing? To quote from the colorfabb website:
"For this material we recommend a minimum of 0.2mm layerheight. Due to the length of the fibers layers lower then 0.15mm can cause issues such as clogging or partial clogging of the nozzle."
Edited by P3DLink to post
