scaling problem
juanmol
Posted · scaling problem
hi all, i'm having a problem while i'm trying to scale a piece. If:
- open the stl
- scale x=101% y=102% z=103%
no problem, works fine, but if i:
- open the stl
- rotate 90º red circle
- scale x=101y=102 and ... z is now at 103.02% (automatic?)
- then i try to correct z=103 but ... now y is at 99.98%
Obviously, Uniform scalling is unchecked. Basically, if i rotate the object, and try to scale, i can't. I only can scale without rotate it. Pleas help.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
