Cura preview window covered in infinite infill
cdyrud
Posted (edited) · Cura preview window covered in infinite infill
Just got back into cura after not being able to open it for a while (fixed by running in windows 8 compatibility). I put a file in and sliced it no problem, but when I tried to look at the preview, the infill had gone wild. The build area, and as far as I could see in all directions, was completely covered from the lowest point of infill in the model to the highest. When I turned the infill percentage to zero it went away, but it seems to be that 1% and higher infill does this. Tried switching infill pattern as well with no change. Cura 4.4 on windows 10.
Edited by cdyrud
New information found during posting process but didn't change title before posting
    Posted · Cura preview window covered in infinite infill
    Looks like a rendering issue. What GPU do you use?
    Does this also happen if you switch Cura to "compatibility mode" in the General preferences and restart Cura?
    That's not the compatibility mode I was talking about. Cura has a built-in compatibility mode that uses OpenGL 2 instead of OpenGL 4. See the "Force layer view compatibility mode" option below:
    Seems to have solved it. Now would this be a normal appearance in this mode? No infill to be seen, tried it on several percentages. I think the time to print changed with the change in infill though, so I would assume it's still there.
    And because it happened just now, any idea why cura will randomly be unable to slice? Or would that be a question for a new thread?
    Edited by cdyrud
