Material Station Lights
Cube3SGM
Posted · Material Station Lights
I have a really strange problem with the Material Station light and the printer case leds. I see the menu on the touch panel to dimm or on/off when printing. But it only controls the led of the material station and not the printer case. The printer case is always on and really shining through the room.
  • I tried to only power on the printer it self (without material station and air manager). The control led brightness doesn't responding. You can slide to low/high brightness but, but nothing happening to the led in the printer case.
  • I put everything together (material station and air manager) still no control over the led in the printer case.
  • Then headed over the control in the web interface, put it on "unavailable" still the led in the print case is on.
  • Then headed to the API and the response say 100. I tried to lower it to 20. It succeed, but the led is still not changed, the API is responding a wrong value I guess.
  • I am on the latest firmware.
Anyone else some solution ?
        • 10 replies
