GregValiant 784
My guess is he had a blockage at a gap between the nozzle and the bottom end of the heat break. With a 1mm nozzle he was pushing a lot of material so heat creep doesn't seem as likely but is still a possibility.
The black marks are filament and there may have been a bit of a leak of plastic past the nozzle threads (although that usually results in loose globs on the print). As the extruding slowed and stopped then any oozing plastic could get blown around by the fans and the strings just ended up getting stuck to the heat block.
Take it apart and clean it up (careful of the wires and don't burn yourself). Make sure the nozzle is seated against the bottom of the heat break (if you also have an all metal), or that the bowden tube has a nice square cut and is mashed against the back end of the nozzle when you tighten the nozzle. The hot end should be near operating temperature when you tighten the nozzle. Oh...and tighten the nozzle with a socket. Only a hack would use pliers.
watermeleon 0
Hi paulrhee2002,
I have the same issue on my ender 3 printer, could you tell me what was wrong with yours or how you fixed it?
