First Layer
zanggi
Hello,
I just started 3D printing and i have a problem...
When i started the printing session, the first layer looked like this. (Image attached)
Why does it look like crap? 😞
I use the Cura default Profile (0.2)
I only changed the infill and added support.
Send Help.
3D printer: Creality CR-10 max
Bed temp: 60
Nozzle temp: 195
    Z offset is the devils work.
    It's the offset or the distance between the nozzle and the bed.
    Different materials like to be squished (Tight offset as in the nozzle is very close to the bed) and some don't so the nozzle is further away, we are talking in like 0.1 MM increments or even smaller when adjusting it but it can be the difference between prints sticking and floating around on the bed.
    I've had off problems that by bringing the nozzle closer to the bed, it fixed it. Especially bed adhesion on glass, if the plastic is cooled before it hits the plate, it don't stick much. So by bringing it closer, it kind of squishes it a little bit which makes it much better
    • Thanks 1
    Posted · First Layer
    Oh okay, thank you for the explanation 🙂
    No problem.
    Stick around here if you are new to 3D printing. I started about 2 months ago and being able to ask all the stupid questions rather than working them out makes all the difference.
    I went through a lot of problems and I still get some but it's much better with the help of everyone on here.
