IMHO UM2+ is outdatted and you will probably need to buy expensive spare parts to keep it working in a short amound of time.
I just purchased an Artillery Sidewinder X1 (v4) for 359 dolars (promo price in black friday) and it cames with TMC silent stepper drives, direct drive with pancake extruder, capacitive end stops, volcano nozzle, colour/touch LCD, build volume of 30x30x40cm, flat cables all around and some other specs that make it a much better machine than my old but good UM2(+).
By the way the Artillery Sidewinder X1 cames as a pre-assembled printer, you just need to screw 4 bolts and conect the flat cables to make it work (10 mins assembly)... I’m very impressed with this new printer and the value for money of it.
Cheers, Fernando Gazzola / 3dSolid
Edited by fergazz
Smithy 1,134
Hi
Your are right, that the UM2+ is quite old and maybe outdated, but it is still a very very good printer and it beats often newer models in some disciplines. So a UM2+ for $700 is a good deal and I would definitely buy it.
The main difference between the UM2+ and newer models are, that they have dual print cores, so you can print in two colors or with a dedicated support material, are network enabled to print via network, active bed leveling and some other features.
I don't know if it helps you for your decision, but my first printer was an UM3, then S5 and I recently bought a used UM2+ Extended because it is a great printer.
Hope it helps a little bit.
geert_2 553
I have two UM2 (non-plus, thus the version before the UM2+) printers and they are still fine for what I need them for, mostly long flat models that need no support.
So if you only need one color and no dissolvable support, it should be okay.
But I would suggest that you make a testprint first, to see if everything still works fine, and the printer isn't abused or damaged (e.g. by dropping, printing abrasive materials, things burned out, damaging mods,...). This is usually repairable, but then the costs might no longer make it the best choice.
