On 8/1/2020 at 11:47 AM, michil said:Hello Anthirx,
thanks for the hints using the original Ultimaker Controller with SKR 1.4. It was very usefull. Currently I build also a SKR 1.4 Turbo into my Ultimaker 2+ and it is working fine.
In the next step I tried to add a BLTouch for AUTO_LEVELING and here I'm having an issue. When trying to do the AUTO_LEVELING it homes the build plate (which is at Z_MAX) at the bottom of the printer. The BED_LEVELING is starting with a HOME and the it starts the BLTouch probe to come out. And here is the problem, the build plate have to be raised to 0mm before starting the probing. ANy hint to get it wokring?
I saw from your images that you also use a probe (even it is a inductive or capacitive probe).
#Kind regards
Michael
Meanwhile I got the AUTO_BED_LEVELING_BILINEAR working but I do not get it working with correct values. I do everything what I found to evaluate the Z Offset for the BLTouch (it's a clone not the original). When I check the Z 0 I still have about 1 to 1.5mm between nozzle and print bed. When I try to print something, The nozzle is directly on the Glass of the printbed, so that no filament could come out. Very strange. Something I have to take care about in Cura?
Any help would be appreciated.
Top Posters In This Topic
11
7
5
4
Popular Days
Jun 21
3
Apr 29
3
Mar 30
2
Apr 28
2
Anthrix 11 posts
Porkpie 7 posts
nitrotech 5 posts
michil 4 posts
Popular Days
Jun 21 2020
Apr 29 2020
Mar 30 2020
Apr 28 2020
Popular Posts
Porkpie
thanks anthrix for your findings! to take things a little bit further, i did some work lately on this particular topic, and these are my findings so far: 1. have some freewheeling diodes added to
Porkpie
this is the final setup of the SKR V1.4 Turbo in my UM2+ chassis. without white cover and extra fan being off, the TMC5160 drivers easily reached 60°C @ 28°C ambient temperature, causing a hard r
Anthrix
So with a bit of modding cable for screen all working with skr 1.4 and ultimaker 2 controller screen, led, buzzer, sd card also working fine. Running marlin 2.0.x. Couple more bits and 32bit Ultimaker
Posted Images
suspiciouspingpong 1
@Anthrix Wow, this is great! I've got a spare MK52 laying around, have exactly this idea with it. It looks like you've simply drilled additional holes in the original base plate? Could you share the locations of the holes you drilled?
PS: why aren't the cables running through the original location?
Anthrix 19
Hi sorry for late replay 🙂 @suspiciouspingpong So for the holes location you'll need to put screw in the end middle hole (that is original hole) and then mark-it rest of the holes.
Front holes are very close to the edge so need to be careful with size of the drill.
Cables are rooted this way to reduce stress on the cable bends. Bigger bend radius less stress on the cable.
michil 0
Hello Anthirx,
#Kind regards
Michael
