Posted · Weird Lines on Print
For some reason I keep getting weird lines on my prints whenever the model has any sort of non-smooth surface. I can’t explain it well in words so I hope the pictures I’ve posted help.
anything to help solve this issue would be a big help.
Thanks!
    Following because I have this happen as well, seemingly randomly. My guess is random over extrusion or under extrusion since it's a solid line around the whole object. Hopefully someone with dónde real answers will pop in.
    Could be over- under extrusion, but I would assume it is a hardware issue. Check your X,Y and Z axles if there is play, tighten all the belts, check your Z screw and clean it.
