16 hours ago, robinmdh said:I hope this was a print head communication error?
The most likely culprits (in my experience) are:
- the pins in the print head connecting to the printcore are dirty, dust and grease can make this happen, just clean them with some alcohol and a q-tip.
- the cable could have developed breaks and might need to be replaced.
- the cable can start to move, it is claimed in by the print head but wear can make it start moving. A bit of tape around the cable right where it is clamped could stop this.
Given the recent change of printcore after never changing it the first one would really be my bet.
Let us know if it helps!
I checked the pins and attempted to clean them, but the issue persisted across all four of my UM print cores and between two different print head assemblies. One of these print head assemblies is brand new.
As for the cable, it may be the issue, but I checked it for continuity across all pins and it did not indicate a break. Each wire of the cable also measured the same resistance, so I am not sure if it could be a short or not. Either way, I will try to source a new cable to see if it fixes it.
Fingers crossed.
robinmdh 93
