DivingDuck 97
It's maybe an good idea to check wether your bed is leveled correct. In most cases this is the problem.
You need first to heat up bed and nozzle to the temperature of the filament you like to use and then follow the leveling procedure with a little peace of normal printing paper (reuse old print paper) and make an additional test cycle when you adjust a hight. The paper should move freely with a little touch scratching to the nozzle on all 5 points within one level cycle.
Good luck.
Framar 38
I've seen a lot of ender 3 with a warped bed. Try to print your model away from the center and look how the first layer looks like.
Good luck!
