How to enable retracts everywere?
Alexus-12
Posted (edited) · How to enable retracts everywere?
Hi, all.
I have found that Cura makes some travel movements without retract. For example, the movements between inner walls, between infill, etc. If the length of these movements too high, the nozzle is lost some amount of material and then I have not enough material when print begins.
I tried to set the minimal distance of travel movements without retract by parameter Retraction minimum travel, but found that this parameter cannot be visible in my settings because has been hidden by active machine (see screenshot). What it means and how to solve it?
Would somebody explaine how to set retract minimum travel distance and enable retract everywere but not only on outer wall?
Edited by Alexus-12
    You are searching for the "combing" option. Disable combing, and Cura will always retract and make straight travel moves. You can also let it enabled but set the max. distance without retract to a low, but non-zero value.
    Edited by P3D
    Quote
    Yes, the combing mode is disabled. But no retcracts on the inner walls and infill.
    This is all settings available for me in this section now.
    Quote
    Did you mean that I need enable it and set Max Comb Distance With No Retract low? As I understand this parameter not working without combing.
    Edited by Alexus-12
    Posted · How to enable retracts everywere?
    31 minutes ago, P3D said:
    Hm, that's really strange... Cura still makes travel moves without retracting?
    Yes.
    I thought that if I disable combing and set the Retraction minimum travel distance, I can control the retract. But this parameter is not available for me (see screenshots).
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
