Hi
Given that not all filament manufacturers supply profiles for Ultimaker, there is going to be a lot of manual setup of filaments. I think some sort of detailed instructions on how to set one up are called for.....
Back to trying to figure out why B,C,D,E, and F don't work on my printer..... (when loaded with legit Ultimaker filament).
Bob
Dim3nsioneer 532
Third party material profiles have to be modified by the manufacturer for usage of their materials in the Material Station. The important feature for this modification is the depriming. It has to happen in such a way that no strings or small filament parts can be lost on the way out and block the way for the next material. Therefore it has to be thoroughly tested and this needs some time. Afaik brands are working on these modifications.
This being said making your own profile for a third party material is of course possible. But you have to make sure that the depriming works flawless or you will probably face consequences which are outside warranty.
If new independent profiles are not sent to the printer, the problem usually is with Cura. Clearing the configuration folder and letting Cura re-initialize itself usually helps. You can also try to restore a known-good Cura backup.
