Extrusion head assembly questions
petermeuris
Posted · Extrusion head assembly questions
Hello all,
The extrusion head assembly went fine. However two questions popped up.
(see
http://wiki.ultimaker.com/Ultimaker_rev ... usion_head
- The thermocouple does not fit into the aluminum block. It gets stuck halfway.
In order to place the fan later I need to get it fully inside the block.
Any ideas on how I should proceed ?
- I had no plumbing tape (PTFE tape) so I did not include this. Is it really needed ?
If so, I should add this of course.
Thanks a lot
Peter
    1) The fitting problem sounds like a mechanical problem. The hole could be too small, or the thermocouple slightly to big. If you have access to a proper machine shop you maybe you could drill out the hole slightly. But remember, the thermocouple needs to make good contact with the block for a proper reading.
    Else, contact [email=sales@ultimaker.com]sales@ultimaker.com[/email] for replacement parts.
    2) Most likely, yes. Else your printer head will leak from the sides.
    I needed some force to push my termocouple in. I haven't been able to do it by hand, i used pincers. You can try that too but you need to be VERY careful because you could damage the two tiny wires: you want to push the cylinder in without putting pressure to the flat end that contains them.
