Body1.stl loads into Cura fine here. It slices ok and says it will print in 17 minutes. That's with no support so the print would fail.
I'd start by backing out the plugins. I have an auto orientation plugin installed, but maybe not the exact same one. I do not yet have OctoPrint set up on this version of Cura.
Bob
uncle_bob 21
Hi
Bob
