Uhm... at 200°C layers do not stick together, i need to stay at 220°C which also makes the object easier to remove from the platform while at 230°C it was really hard.
At 0.2mm layers height problem (2) is solved.
But i want to try another slicer because i think something is wrong with slic3r. By the way Daid, how do i set the extrusion temperature in SkeinPyPy-NewUI-Beta2 ? I don't see any field to configure it.
Daid 306
Perfect moment to blame slic3r! :mrgreen: (just joking)
The corner blobs could be caused by a high temperature. Even if the package says 220C, try lower. Because PLA already starts to go soft at 70C, and is usually printable at 200C.
I would suggest, go to 0.2mm layers, even at at 0.3mm layers I had problems with layers not sticking properly to each other. Also, both other problems look like "to litle extrusion", which might indicate your "Steps per E" is not right for your machine, or you didn't measure your filament thickness right.
