Torgeir:
Thanks for your reply.
Both jumpers for the safety's are present.
I am getting
23.9V at tp21
3.2V at tp16
4.8v at tp16
1.1V at the resistors in the schematic at tp405,433,418.
None of the axis move. Even the Z when it says to turn the knob
to move the bed close to the printhead.
Should have occurred to me that could cause the error I am getting.
Dan
Torgeir 228
Hi Spenter,
Since this is the first startup of your system, there is a few thing to check..
First, did you install the two safety links? Those two link can be used to cutoff the 24VDC to all heaters and stepper motors. so if this one is missing, you would not have power to the stepper motors to move.
During the setup the Z stepper will move toward the z-stop in order to synchronize. If this voltage is not present, no movement of the bed toward the stop, so after a timeout the Z-switch fail is flagged and it will display; "Z switch broken".
When turning on the power switch for the printer, you should be able to hear a solid click when the relay is activating.
To verify that this voltage is present, do as follows:
Also the 24 VDC "switch" the (only one) relay K1 might be faulty, check the TP21 (Test Point) for 24 VDC on the underside of the PCB. You will find the test point close to the heater connector.
I'll assume you know how to do this procedure.
Lets do this check as a start.
Good luck
Thanks
Torgeir
