UM3 pushes out bowden from feeder
esopalumpa
Posted · UM3 pushes out bowden from feeder
On 3/29/2020 at 5:34 PM, esopalumpa said:
‣ Push the collet down
‣ insert the bowden and push it in with some force
‣ pull the collet up (with some force) while still pushing the bowden down
‣ insert the clip
The original clip is 1.4mm thick. I designed clips with 1.5 mm, 1.6 mm, 1.7 mm and 1.8 mm to increase tension on the collet if necessary.
Ultimaker-3-bowdenclip-1,4mm.stl 3.35 MB · 21 downloads Ultimaker-3-bowdenclip-1,5mm.stl 3.35 MB · 19 downloads Ultimaker-3-bowdenclip-1,6mm.stl 3.34 MB · 22 downloads Ultimaker-3-bowdenclip-1,7mm.stl 3.35 MB · 18 downloads Ultimaker-3-bowdenclip-1,8mm.stl 3.35 MB · 16 downloads
Thank you for the files; I used the 1.6mm and it solved my problem,
Minke
