Ultimaker Cura 4.5 now available
Guest maht
Posted · Ultimaker Cura 4.5 now available
16 hours ago, tinkergnome said:
well, a missing comma here and there can ruin your day... 🙂
There are validator tools for json-files (https://jsonlint.com/ for example). It's a quick check and can save you hours sometimes.
Good luck!
Man i just LOVE hanging out with smart people
Thanks so much.
 solved
    Cura 4.5.0 - mutli color prints
        I hope i am posting in the right area.(please let me know )
    i have a curiosity, not necessarily a bug(not sure). when i slice a multi color print all seems fine.
    when i print it an the gcode gets to the T1 (change tool) it perforfn the retraction over the work and then pauses for 30 -60 sec .....and then moves to the prime tower. i do not understand where the pause comes from... it it not in the gcode.
    where would be a good place to start to look
    HtRabbit
    I had that problem with other printers, not with UM5 so I think it depends on your machine. It has something to do with waiting for temperature to change. You have a standby temperature and an extrusion temperature M109.
    Does not run on MAC os Catalina. Version 4.4.1 works fine. Installed as an update and as a separate application. The result is the same.
    @OI_3 please post the log.  A lot of people say cura is slow and it's often related to network issues and is often helped by disabling plugins related to printing over the network.  Are you saying it's slow or it doesn't launch at all or it launches but.... something?  Please define "does not run" with more details.
    Process:               cura [10456]
    Path:                  /Applications/Ultimaker Cura 2.app/Contents/MacOS/cura
    Identifier:            nl.ultimaker.cura
    Version:               4.5 (4.5.0)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           cura [10456]
    User ID:               501
    Date/Time:             2020-03-18 18:50:42.651 +0300
    OS Version:            Mac OS X 10.15.3 (19D76)
    Report Version:        12
    Anonymous UUID:        58760EB6-4A71-832E-EC2B-0E460194862F
    Time Awake Since Boot: 37000 seconds
    System Integrity Protection: disabled
    Crashed Thread:        0
    Exception Type:        EXC_CRASH (SIGABRT)
    Exception Codes:       0x0000000000000000, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Application Specific Information:
    abort() called
    Thread 0 Crashed:
    0   libsystem_kernel.dylib            0x00007fff6d0557fa __pthread_kill + 10
    1   libsystem_c.dylib                 0x00007fff6cfdca1c abort + 120
    2   nl.ultimaker.cura                 0x000000010121fe3e Py_FatalError + 462
    3   nl.ultimaker.cura                 0x00000001011f27d1 _Py_CheckRecursiveCall + 65
    4   nl.ultimaker.cura                 0x00000001011310a6 PyObject_Call + 86
    5   nl.ultimaker.cura                 0x0000000101130e1e _PyObject_CallMethodId + 318
    6   nl.ultimaker.cura                 0x0000000101220939 0x101125000 + 1030457
    7   nl.ultimaker.cura                 0x000000010121fe39 Py_FatalError + 457
    8   nl.ultimaker.cura                 0x00000001011f27d1 _Py_CheckRecursiveCall + 65
    9   nl.ultimaker.cura                 0x00000001011310a6 PyObject_Call + 86
    10  nl.ultimaker.cura                 0x000000010119334d 0x101125000 + 451405
    11  nl.ultimaker.cura                 0x00000001011f3a8a PyEval_EvalFrameEx + 4538
    12  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    13  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    14  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    15  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    16  nl.ultimaker.cura                 0x0000000101146bed 0x101125000 + 138221
    17  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    18  nl.ultimaker.cura                 0x0000000101193111 0x101125000 + 450833
    19  nl.ultimaker.cura                 0x00000001011f6cc9 PyEval_EvalFrameEx + 17401
    20  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    21  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    22  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    23  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    24  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    25  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    26  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    27  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    28  nl.ultimaker.cura                 0x0000000101146bed 0x101125000 + 138221
    29  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    30  nl.ultimaker.cura                 0x00000001011905ee 0x101125000 + 439790
    31  nl.ultimaker.cura                 0x000000010118ca89 0x101125000 + 424585
    32  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    33  nl.ultimaker.cura                 0x00000001011f8a33 PyEval_EvalFrameEx + 24931
    34  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    35  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    36  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    37  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    38  nl.ultimaker.cura                 0x000000010119078b 0x101125000 + 440203
    39  nl.ultimaker.cura                 0x000000010118c992 0x101125000 + 424338
    40  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    41  nl.ultimaker.cura                 0x00000001011f8a33 PyEval_EvalFrameEx + 24931
    42  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    43  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    44  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    45  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    46  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    47  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    48  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    49  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    50  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    51  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    52  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    53  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    54  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    55  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    56  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    57  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    58  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    59  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    60  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    61  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    62  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    63  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    64  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    65  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    66  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    67  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    68  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    69  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    70  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    71  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    72  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    73  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    74  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    75  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    76  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    77  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    78  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    79  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    80  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    81  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    82  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    83  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    84  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    85  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    86  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    87  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    88  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    89  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    90  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    91  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    92  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    93  nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    94  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    95  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    96  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    97  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    98  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    99  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    100 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    101 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    102 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    103 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    104 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    105 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    106 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    107 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    108 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    109 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    110 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    111 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    112 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    113 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    114 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    115 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    116 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    117 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    118 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    119 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    120 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    121 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    122 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    123 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    124 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    125 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    126 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    127 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    128 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    129 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    130 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    131 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    132 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    133 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    134 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    135 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    136 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    137 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    138 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    139 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    140 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    141 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    142 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    143 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    144 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    145 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    146 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    147 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    148 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    149 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    150 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    151 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    152 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    153 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    154 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    155 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    156 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    157 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    158 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    159 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    160 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    161 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    162 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    163 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    164 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    165 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    166 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    167 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    168 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    169 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    170 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    171 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    172 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    173 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    174 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    175 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    176 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    177 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    178 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    179 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    180 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    181 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    182 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    183 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    184 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    185 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    186 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    187 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    188 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    189 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    190 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    191 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    192 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    193 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    194 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    195 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    196 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    197 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    198 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    199 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    200 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    201 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    202 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    203 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    204 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    205 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    206 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    207 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    208 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    209 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    210 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    211 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    212 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    213 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    214 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    215 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    216 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    217 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    218 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    219 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    220 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    221 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    222 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    223 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    224 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    225 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    226 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    227 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    228 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    229 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    230 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    231 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    232 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    233 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    234 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    235 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    236 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    237 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    238 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    239 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    240 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    241 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    242 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    243 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    244 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    245 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    246 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    247 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    248 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    249 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    250 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    251 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    252 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    253 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    254 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    255 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    256 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    257 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    258 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    259 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    260 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    261 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    262 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    263 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    264 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    265 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    266 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    267 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    268 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    269 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    270 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    271 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    272 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    273 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    274 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    275 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    276 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    277 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    278 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    279 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    280 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    281 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    282 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    283 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    284 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    285 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    286 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    287 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    288 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    289 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    290 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    291 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    292 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    293 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    294 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    295 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    296 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    297 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    298 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    299 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    300 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    301 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    302 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    303 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    304 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    305 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    306 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    307 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    308 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    309 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    310 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    311 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    312 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    313 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    314 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    315 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    316 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    317 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    318 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    319 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    320 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    321 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    322 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    323 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    324 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    325 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    326 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    327 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    328 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    329 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    330 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    331 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    332 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    333 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    334 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    335 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    336 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    337 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    338 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    339 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    340 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    341 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    342 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    343 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    344 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    345 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    346 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    347 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    348 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    349 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    350 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    351 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    352 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    353 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    354 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    355 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    356 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    357 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    358 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    359 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    360 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    361 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    362 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    363 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    364 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    365 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    366 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    367 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    368 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    369 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    370 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    371 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    372 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    373 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    374 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    375 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    376 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    377 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    378 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    379 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    380 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    381 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    382 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    383 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    384 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    385 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    386 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    387 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    388 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    389 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    390 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    391 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    392 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    393 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    394 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    395 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    396 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    397 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    398 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    399 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    400 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    401 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    402 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    403 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    404 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    405 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    406 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    407 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    408 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    409 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    410 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    411 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    412 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    413 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    414 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    415 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    416 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    417 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    418 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    419 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    420 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    421 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    422 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    423 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    424 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    425 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    426 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    427 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    428 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    429 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    430 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    431 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    432 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    433 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    434 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    435 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    436 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    437 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    438 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    439 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    440 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    441 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    442 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    443 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    444 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    445 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    446 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    447 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    448 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    449 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    450 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    451 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    452 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    453 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    454 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    455 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    456 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    457 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    458 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    459 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    460 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    461 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    462 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    463 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    464 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    465 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    466 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    467 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    468 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    469 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    470 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    471 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    472 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    473 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    474 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    475 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    476 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    477 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    478 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    479 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    480 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    481 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    482 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    483 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    484 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    485 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    486 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    487 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    488 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    489 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    490 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    491 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    492 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    493 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    494 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    495 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    496 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    497 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    498 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    499 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    500 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    501 nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    502 nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    503 nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    504 nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    505 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    506 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    507 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    508 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    509 nl.ultimaker.cura                 0x00000001011fdd90 0x101125000 + 888208
    510 nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    511 nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    Thread 1:
    0   libsystem_pthread.dylib           0x00007fff6d10e818 start_wqthread + 0
    Thread 2:
    Thread 3:: Qt bearer thread
    0   libsystem_kernel.dylib            0x00007fff6d055896 poll + 10
    1   libQt5Core.5.dylib                0x00000001020657b7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 871
    2   libQt5Core.5.dylib                0x00000001020072f1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 417
    3   libQt5Core.5.dylib                0x0000000101e31133 QThread::exec() + 115
    4   libQt5Core.5.dylib                0x0000000101e351e5 0x101e07000 + 188901
    5   libsystem_pthread.dylib           0x00007fff6d112e65 _pthread_start + 148
    6   libsystem_pthread.dylib           0x00007fff6d10e83b thread_start + 15
    Thread 4:
    0   libsystem_kernel.dylib            0x00007fff6d051ce6 __psynch_cvwait + 10
    1   nl.ultimaker.cura                 0x0000000101237abb PyThread_acquire_lock_timed + 331
    2   nl.ultimaker.cura                 0x000000010123cd7f 0x101125000 + 1146239
    3   nl.ultimaker.cura                 0x000000010123ca60 0x101125000 + 1145440
    4   nl.ultimaker.cura                 0x000000010117a4cc PyCFunction_Call + 60
    5   nl.ultimaker.cura                 0x00000001011f8ccf PyEval_EvalFrameEx + 25599
    12  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    13  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    14  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    16  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    17  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    18  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    19  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    20  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    21  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    22  nl.ultimaker.cura                 0x0000000101146bed 0x101125000 + 138221
    24  nl.ultimaker.cura                 0x00000001011fc425 PyEval_CallObjectWithKeywords + 165
    25  nl.ultimaker.cura                 0x000000010123d606 0x101125000 + 1148422
    26  libsystem_pthread.dylib           0x00007fff6d112e65 _pthread_start + 148
    27  libsystem_pthread.dylib           0x00007fff6d10e83b thread_start + 15
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:: com.apple.NSEventThread
    0   libsystem_kernel.dylib            0x00007fff6d04f25a mach_msg_trap + 10
    1   libsystem_kernel.dylib            0x00007fff6d04f5d0 mach_msg + 60
    2   com.apple.CoreFoundation          0x00007fff35a03d0b __CFRunLoopServiceMachPort + 322
    3   com.apple.CoreFoundation          0x00007fff35a028e7 __CFRunLoopRun + 1695
    4   com.apple.CoreFoundation          0x00007fff35a01bd3 CFRunLoopRunSpecific + 499
    5   com.apple.AppKit                  0x00007fff32d6a792 _NSEventThread + 132
    Thread 9:
    0   libsystem_kernel.dylib            0x00007fff6d05280e __recvfrom + 10
    1   Arcus.so                          0x00000001014d2b04 Arcus::Socket::Private::receiveNextMessage() + 180
    2   Arcus.so                          0x00000001014d1fcd Arcus::Socket::Private::run() + 733
    3   Arcus.so                          0x00000001014d4274 void* std::__1::__thread_proxy<std::__1::tuple<Arcus::Socket::listen(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, int)::$_1> >(void*) + 100
    4   libsystem_pthread.dylib           0x00007fff6d112e65 _pthread_start + 148
    5   libsystem_pthread.dylib           0x00007fff6d10e83b thread_start + 15
    Thread 10:
    0   libsystem_kernel.dylib            0x00007fff6d04fc7e read + 10
    1   nl.ultimaker.cura                 0x000000010126eed6 0x101125000 + 1351382
    2   nl.ultimaker.cura                 0x000000010117a5ba PyCFunction_Call + 298
    4   nl.ultimaker.cura                 0x0000000101131af7 PyObject_CallMethodObjArgs + 407
    5   nl.ultimaker.cura                 0x00000001012727b7 0x101125000 + 1365943
    6   nl.ultimaker.cura                 0x000000010127207b 0x101125000 + 1364091
    7   nl.ultimaker.cura                 0x0000000101273cef 0x101125000 + 1371375
    8   nl.ultimaker.cura                 0x000000010117a535 PyCFunction_Call + 165
    9   nl.ultimaker.cura                 0x00000001011f8ccf PyEval_EvalFrameEx + 25599
    10  nl.ultimaker.cura                 0x00000001011fd4b2 0x101125000 + 885938
    11  nl.ultimaker.cura                 0x00000001011f28ae PyEval_EvalCodeEx + 78
    12  nl.ultimaker.cura                 0x000000010115a89d 0x101125000 + 219293
    13  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    14  nl.ultimaker.cura                 0x00000001011f94ed PyEval_EvalFrameEx + 27677
    15  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    16  nl.ultimaker.cura                 0x00000001011f8733 PyEval_EvalFrameEx + 24163
    17  nl.ultimaker.cura                 0x00000001011fdd12 0x101125000 + 888082
    23  nl.ultimaker.cura                 0x0000000101146bed 0x101125000 + 138221
    24  nl.ultimaker.cura                 0x00000001011310b5 PyObject_Call + 101
    25  nl.ultimaker.cura                 0x00000001011fc425 PyEval_CallObjectWithKeywords + 165
    26  nl.ultimaker.cura                 0x000000010123d606 0x101125000 + 1148422
    27  libsystem_pthread.dylib           0x00007fff6d112e65 _pthread_start + 148
    28  libsystem_pthread.dylib           0x00007fff6d10e83b thread_start + 15
    Thread 11:
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x0000000103221dc0  rcx: 0x00007ffeeea5ffe8  rdx: 0x0000000000000000
      rdi: 0x0000000000000307  rsi: 0x0000000000000006  rbp: 0x00007ffeeea60010  rsp: 0x00007ffeeea5ffe8
       r8: 0x00000000000130a8   r9: 0x0000000000000000  r10: 0x0000000103221dc0  r11: 0x0000000000000246
      r12: 0x0000000000000307  r13: 0x00006000052d4c98  r14: 0x0000000000000006  r15: 0x0000000000000016
      rip: 0x00007fff6d0557fa  rfl: 0x0000000000000246  cr2: 0x0000000101300e28
    Logical CPU:     0
    Error Code:      0x02000148
    Trap Number:     133
    Binary Images:
           0x101125000 -        0x1012cfffb +nl.ultimaker.cura (4.5 - 4.5.0) <B42412A8-D4E5-3593-8CE2-4C0C3B583E3F> /Applications/Ultimaker Cura 2.app/Contents/MacOS/cura
           0x1013d5000 -        0x1013d8ffb +zlib.cpython-35-darwin.so (0) <9C54D143-3E6C-3E78-AE12-F93255856F82> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/zlib.cpython-35-darwin.so
           0x1013dd000 -        0x1013f1ff7 +libz.1.dylib (0) <0B0E19C8-CDA1-357B-BA61-64B88ADB17A3> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libz.1.dylib
           0x1014bb000 -        0x1014bbfff +_heapq.cpython-35-darwin.so (0) <12B425D0-0F6A-3E3B-9A14-EA58D35B58AB> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_heapq.cpython-35-darwin.so
           0x1014bf000 -        0x1014c3ffb +_struct.cpython-35-darwin.so (0) <0D09CF70-A18A-38B1-AE34-366972021FF7> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_struct.cpython-35-darwin.so
           0x1014cc000 -        0x1015b6ff7 +Arcus.so (0) <981596A3-CB47-3A2A-A2A9-2FCEC0212F7A> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/Arcus.so
           0x101648000 -        0x10165bfff +sip.so (0) <5155672D-D6BD-3267-9808-F4A9C757D231> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/sip.so
           0x101666000 -        0x10169aff7 +Savitar.so (0) <774D5D2B-BE47-3EA1-B738-DA373865BBF2> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/Savitar.so
           0x1016b2000 -        0x1016b6ff7 +math.cpython-35-darwin.so (0) <DB932B6C-1AA4-3C36-8826-7C212D1AFB45> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/math.cpython-35-darwin.so
           0x1016bd000 -        0x1016c8ff7 +_datetime.cpython-35-darwin.so (0) <105972CC-C6D1-3BD8-A16A-FEF5F906490E> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_datetime.cpython-35-darwin.so
           0x101734000 -        0x101735ffb +_bz2.cpython-35-darwin.so (0) <124FD5A3-E80F-3450-A432-C277FF46D390> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_bz2.cpython-35-darwin.so
           0x101739000 -        0x10173cfff +_lzma.cpython-35-darwin.so (0) <EBD6021D-736F-32EA-8CED-73B546CF92B7> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_lzma.cpython-35-darwin.so
           0x101742000 -        0x101761ff3 +liblzma.5.dylib (0) <0DFA41CA-8B8F-3F67-8269-88A976A594CD> /Applications/Ultimaker Cura 2.app/Contents/MacOS/liblzma.5.dylib
           0x101775000 -        0x101775ffb +grp.cpython-35-darwin.so (0) <2FD6E487-A434-3868-A8E4-DC033457B2E3> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/grp.cpython-35-darwin.so
           0x101778000 -        0x10177aff7 +_hashlib.cpython-35-darwin.so (0) <F6C8B9C8-4D6D-337A-B17A-9FAB0C276A05> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_hashlib.cpython-35-darwin.so
           0x10177f000 -        0x1017c2fff +libssl.1.0.0.dylib (0) <68D7EA4B-0AB2-3AB7-8BF5-4300968411A4> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libssl.1.0.0.dylib
           0x1017e2000 -        0x10199f927 +libcrypto.1.0.0.dylib (0) <52AFC6CE-4429-33E6-A536-CCF3C99E98CB> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libcrypto.1.0.0.dylib
           0x101a1f000 -        0x101a20fff +_random.cpython-35-darwin.so (0) <815CD49A-68CF-3F59-A09D-5C0BCE4816E8> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_random.cpython-35-darwin.so
           0x101a23000 -        0x101a23ffb +_opcode.cpython-35-darwin.so (0) <A2479C66-6115-3DE4-B929-4215B5A444FC> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_opcode.cpython-35-darwin.so
           0x101a26000 -        0x101a27ffb +_posixsubprocess.cpython-35-darwin.so (0) <0F0DEB88-E0DA-3A5C-AC2C-9D30E274E25B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_posixsubprocess.cpython-35-darwin.so
           0x101a2b000 -        0x101a2dff7 +select.cpython-35-darwin.so (0) <5A3384E3-4C02-3F8A-A382-EFD58E1E6DB2> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/select.cpython-35-darwin.so
           0x101a33000 -        0x101a43ff7 +_ctypes.cpython-35-darwin.so (0) <4FD99AA0-9955-34A8-83D5-88177C32B0D6> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_ctypes.cpython-35-darwin.so
           0x101a55000 -        0x101a5affb +_json.cpython-35-darwin.so (0) <8FC242A6-4308-3464-ACD4-D6160975D0D0> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_json.cpython-35-darwin.so
           0x101a5f000 -        0x101a67fff +_socket.cpython-35-darwin.so (0) <A85E618D-9A2F-3EF8-91A1-4DF102A3E6C3> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_socket.cpython-35-darwin.so
           0x101a73000 -        0x101a7eff7 +_ssl.cpython-35-darwin.so (0) <813E56D3-2DB3-3FA0-B519-CF3FE4C50F6B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_ssl.cpython-35-darwin.so
           0x101a8d000 -        0x101a90ff3 +binascii.cpython-35-darwin.so (0) <8C20FD51-BD3E-33E6-B5A3-005C7B885479> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/binascii.cpython-35-darwin.so
           0x101b55000 -        0x101b55fff +_bisect.cpython-35-darwin.so (0) <A2CF6152-DD33-36EA-9B4A-A171B09366C0> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_bisect.cpython-35-darwin.so
           0x101b58000 -        0x101b58ff3 +_scproxy.cpython-35-darwin.so (0) <48672D84-949E-3A1F-8A5F-C8E62466622B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_scproxy.cpython-35-darwin.so
           0x101b5b000 -        0x101ca2ff7 +PyQt5.QtCore.so (0) <AA79A4FE-4143-3DA8-8497-4D7449509BAF> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtCore.so
           0x101e07000 -        0x102306ff7 +libQt5Core.5.dylib (0) <D7850E65-5076-379F-87DC-6F0F7EF35E0B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Core.5.dylib
           0x10241d000 -        0x10267cff3 +PyQt5.QtWidgets.so (0) <CD338BEB-4C11-31CA-83E0-36FEB4225FE4> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtWidgets.so
           0x10295a000 -        0x102dacff7 +libQt5Widgets.5.dylib (0) <F06A8527-7662-3949-BFAF-31A268FD6A85> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Widgets.5.dylib
           0x102f55000 -        0x102f8dfff +libquadmath.0.dylib (0) <E5A7047C-6353-38E3-8669-A2503D7D6AD9> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libquadmath.0.dylib
           0x102fa0000 -        0x102fb5fef +libgcc_s.1.dylib (1) <2F068636-B3CC-3D99-B93D-E862197BC7AE> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libgcc_s.1.dylib
           0x102fc5000 -        0x1030f9ffb +umath.cpython-35-darwin.so (0) <4018C82A-015A-3F30-B3DF-5006A0EFDA20> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/core/umath.cpython-35-darwin.so
           0x103140000 -        0x103141ff3 +lapack_lite.cpython-35-darwin.so (0) <71102557-2A36-3D7D-892A-AD484CB423CA> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/linalg/lapack_lite.cpython-35-darwin.so
           0x103145000 -        0x10314effb +fftpack_lite.cpython-35-darwin.so (0) <F333E546-7F1A-3395-A2BC-BBBE720A299D> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/fft/fftpack_lite.cpython-35-darwin.so
           0x103152000 -        0x103153ff7 +fcntl.cpython-35-darwin.so (0) <A96CCE2F-891B-34BB-8CBF-87E7D99054ED> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/fcntl.cpython-35-darwin.so
           0x103158000 -        0x1031e8cb7  dyld (733.8) <EBC07CB6-870A-3A8E-B48A-67F62EA161F3> /usr/lib/dyld
           0x104d8c000 -        0x1051d9fe3 +libQt5Gui.5.dylib (0) <226363AE-C36D-30E0-AA98-C0071C5EB5C2> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Gui.5.dylib
           0x1052e6000 -        0x10544dff3 +PyQt5.QtGui.so (0) <809C4BB4-5C75-3C04-B549-051A06B3AAE0> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtGui.so
           0x1055da000 -        0x105750ff3 +multiarray.cpython-35-darwin.so (0) <D310AB26-72C5-3452-ABF0-D3068FDB3042> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/core/multiarray.cpython-35-darwin.so
           0x105828000 -        0x10908a667 +libopenblasp-r0.3.5.dylib (0) <3218A30B-E0AB-3441-9841-95FB8F6A6A5F> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libopenblasp-r0.3.5.dylib
           0x109364000 -        0x109595fef +libgfortran.5.dylib (0) <7A3F3AFE-D02C-3A88-91CA-CEFF5B0740EB> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libgfortran.5.dylib
           0x10f622000 -        0x10f633ffb +_pickle.cpython-35-darwin.so (0) <C6B50725-FDC5-318E-B00B-318D8559DE0E> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_pickle.cpython-35-darwin.so
           0x10f63f000 -        0x10f657fff +_umath_linalg.cpython-35-darwin.so (0) <4EAECC9C-0984-32B0-A505-6DEE255A7A2C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/linalg/_umath_linalg.cpython-35-darwin.so
           0x10f665000 -        0x10f6abffb +_decimal.cpython-35-darwin.so (0) <5EF92342-9E49-31C6-A064-C0F095FA6BB6> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_decimal.cpython-35-darwin.so
           0x10f6c9000 -        0x10f6d6ffb +_multiarray_tests.cpython-35-darwin.so (0) <72373677-74E0-3645-B148-4B03CE7D08DC> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/core/_multiarray_tests.cpython-35-darwin.so
           0x10f6e5000 -        0x10f77ffff +mtrand.cpython-35-darwin.so (0) <2AF57592-33B4-3B77-ADBA-EC5E7ABDE578> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/numpy/random/mtrand.cpython-35-darwin.so
           0x10f7f9000 -        0x10f803fff +_ccallback_c.cpython-35-darwin.so (0) <61781908-7B61-34EB-BF85-CEF6852565E6> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/_lib/_ccallback_c.cpython-35-darwin.so
           0x10f80d000 -        0x10fb89ff7 +_sparsetools.cpython-35-darwin.so (0) <6FB7BC03-8F4B-3FFA-BE4D-32110BEA4532> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/_sparsetools.cpython-35-darwin.so
           0x10fc69000 -        0x10fccdfff +_csparsetools.cpython-35-darwin.so (0) <6335A1B4-8376-38B6-AAFC-D9D302ACEA7C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/_csparsetools.cpython-35-darwin.so
           0x10fceb000 -        0x10fd1dff3 +_shortest_path.cpython-35-darwin.so (0) <63B0E6E7-446E-3844-B3ED-AACB4E610A32> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_shortest_path.cpython-35-darwin.so
           0x10fd30000 -        0x10fd4bfff +_tools.cpython-35-darwin.so (0) <9252D42F-EA6B-3E28-B5CB-DCEE44B931AE> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_tools.cpython-35-darwin.so
           0x10fd5b000 -        0x10fd76fff +_traversal.cpython-35-darwin.so (0) <B127C1F8-53B3-3095-A819-F976B2EC9EC2> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_traversal.cpython-35-darwin.so
           0x10fd84000 -        0x10fda3ffb +_min_spanning_tree.cpython-35-darwin.so (0) <645E4CDF-B38A-3FDF-A957-B495271BC056> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_min_spanning_tree.cpython-35-darwin.so
           0x10fdb6000 -        0x10fdefff7 +_reordering.cpython-35-darwin.so (0) <B558ACAE-07F7-3459-B457-C9227933E428> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_reordering.cpython-35-darwin.so
           0x10fe0a000 -        0x10fe83fff +ckdtree.cpython-35-darwin.so (0) <ED79ED80-4CAE-3ECD-B7E5-8F34EE112A71> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/spatial/ckdtree.cpython-35-darwin.so
           0x10feaa000 -        0x10ff6eff3 +qhull.cpython-35-darwin.so (0) <12FE6706-3331-3923-8C81-8A75D9CE5752> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/spatial/qhull.cpython-35-darwin.so
           0x10ffa8000 -        0x10ffadffb +messagestream.cpython-35-darwin.so (0) <1C5E425B-077A-37A0-968F-62818153907E> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/_lib/messagestream.cpython-35-darwin.so
           0x10ffb4000 -        0x10ffd2ffb +_voronoi.cpython-35-darwin.so (0) <1FC8D75A-D318-394F-8DF4-6818E4C56C5D> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/spatial/_voronoi.cpython-35-darwin.so
           0x10ffe4000 -        0x10fff2fff +_distance_wrap.cpython-35-darwin.so (0) <B1DDB05F-D6E8-3F4B-B25A-FD6B6B458287> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/spatial/_distance_wrap.cpython-35-darwin.so
           0x10fffc000 -        0x11001affb +_hausdorff.cpython-35-darwin.so (0) <DC3D2A83-BF7E-303C-90B2-AAF8BEC4059B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/spatial/_hausdorff.cpython-35-darwin.so
           0x21002c000 -        0x210080ff7 +_fblas.cpython-35-darwin.so (0) <5A81C29E-28EE-328D-B588-FBE441E78A8C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/_fblas.cpython-35-darwin.so
           0x3100b8000 -        0x310187ff7 +_flapack.cpython-35-darwin.so (0) <8EA64E64-24CD-3F74-A28C-70A35552128A> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/_flapack.cpython-35-darwin.so
           0x410215000 -        0x41021fff7 +_flinalg.cpython-35-darwin.so (0) <3A892377-FA84-36F2-862E-EC19DD72B3B7> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/_flinalg.cpython-35-darwin.so
           0x410227000 -        0x41024efff +_solve_toeplitz.cpython-35-darwin.so (0) <D38BF579-28F8-3C61-A12E-CE20A0301BBC> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/_solve_toeplitz.cpython-35-darwin.so
           0x410264000 -        0x41029efff +_decomp_update.cpython-35-darwin.so (0) <E2B35E80-62D9-31C6-8644-ED8FCF040A3F> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/_decomp_update.cpython-35-darwin.so
           0x5102b3000 -        0x5102dcfff +cython_blas.cpython-35-darwin.so (0) <33690E69-8833-3239-9418-B63A10D28DE5> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/cython_blas.cpython-35-darwin.so
           0x6102f9000 -        0x610371ff7 +cython_lapack.cpython-35-darwin.so (0) <49EFB1B1-87B2-3528-83CD-614F1154261F> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/linalg/cython_lapack.cpython-35-darwin.so
           0x7103ce000 -        0x710542fef +_ufuncs.cpython-35-darwin.so (0) <8A178086-54D4-3B8A-9CF3-C08CB2DC859C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/special/_ufuncs.cpython-35-darwin.so
           0x7105b8000 -        0x7105cdfff +_ufuncs_cxx.cpython-35-darwin.so (0) <574F6C56-67FD-3BFC-8D54-38DF6909B4D8> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/special/_ufuncs_cxx.cpython-35-darwin.so
           0x8105dc000 -        0x810697fef +specfun.cpython-35-darwin.so (0) <9493078D-B7E4-385D-98B7-98AFB61666E2> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/special/specfun.cpython-35-darwin.so
           0x8106ba000 -        0x8106beff3 +_comb.cpython-35-darwin.so (0) <660E0F65-9445-3484-AE13-75189D63763B> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/special/_comb.cpython-35-darwin.so
           0x8106c3000 -        0x8106d0ff3 +_ellip_harm_2.cpython-35-darwin.so (0) <20AD49F8-02FE-3FAC-BE9B-0FE4EF499419> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/special/_ellip_harm_2.cpython-35-darwin.so
           0x8106da000 -        0x810762fff +libfreetype.dylib (19.6) <51ECD8C8-7B61-3A4A-8C22-0E207ACC2383> /Users/USER/Library/Application Support/cura/*/libfreetype.dylib
           0x81085b000 -        0x8108a2ff3 +PyQt5.QtQml.so (0) <53AFF321-535C-3C7B-97D4-1FE193CF1714> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtQml.so
           0x810925000 -        0x810c46ff7 +libQt5Qml.5.dylib (0) <D4C6B6F8-1236-30E5-BC26-1B4306442BC5> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Qml.5.dylib
           0x810cff000 -        0x810e0cff7 +libQt5Network.5.dylib (0) <C10AFA82-1B1E-379C-A506-DDCC5E3C53D7> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Network.5.dylib
           0x810e59000 -        0x810eb5ff3 +PyQt5.QtNetwork.so (0) <52801FBF-DF55-3223-BA97-21D3733585C6> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtNetwork.so
           0x810f26000 -        0x810f8dff3 +PyQt5.QtQuick.so (0) <79E5AD39-74FA-39BC-8846-A92336EA05EC> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5.QtQuick.so
           0x811046000 -        0x811316ff7 +libQt5Quick.5.dylib (0) <22FFC65C-876E-388D-8E00-E8C4C46AA471> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Quick.5.dylib
           0x8114a1000 -        0x81156effb +unicodedata.cpython-35-darwin.so (0) <119772AD-1C02-3622-BFC1-4BB7F23936AF> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/unicodedata.cpython-35-darwin.so
           0x8115ab000 -        0x8115b0ff3 +array.cpython-35-darwin.so (0) <4A19A9F7-3EE6-3E3E-AF7A-29E856D4A308> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/array.cpython-35-darwin.so
           0x8115ba000 -        0x8115d8ff7 +libgeos_c.1.dylib (0) <1A9E47BC-B15A-373B-9F10-CDA946B21C84> /Applications/Ultimaker Cura 2.app/Contents/Resources/lib/python3.5/shapely/.dylibs/libgeos_c.1.dylib
           0x8115eb000 -        0x8116abfff +libgeos.3.7.0.dylib (0) <9D0B5BFC-9FE3-30A5-B411-814990F6A66C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libgeos.3.7.0.dylib
           0x81174e000 -        0x81176aff3 +_speedups.cpython-35-darwin.so (0) <5D57FBA3-2C01-3DF5-B00B-8A72F66C8F94> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/shapely/speedups/_speedups.cpython-35-darwin.so
           0x811779000 -        0x811797ff7 +libgeos_c.1.dylib (0) <1A9E47BC-B15A-373B-9F10-CDA946B21C84> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libgeos_c.1.dylib
           0x911819000 -        0x911820ff7 +minpack2.cpython-35-darwin.so (0) <23A57629-4275-3141-B353-13F109B2CE43> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/minpack2.cpython-35-darwin.so
           0x911825000 -        0x91185cff7 +_trlib.cpython-35-darwin.so (0) <F2C3CF08-CD82-343C-A8C7-F2A2BF3C4ECC> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_trlib/_trlib.cpython-35-darwin.so
           0xa11875000 -        0xa118a1fff +_iterative.cpython-35-darwin.so (0) <73C67166-BEA3-3E14-ACDA-5185843D1A8E> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/linalg/isolve/_iterative.cpython-35-darwin.so
           0xa118b8000 -        0xa11906fff +_superlu.cpython-35-darwin.so (0) <ADEEB583-AD98-3FBD-8521-E1B4248CB2BE> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/linalg/dsolve/_superlu.cpython-35-darwin.so
           0xb1191e000 -        0xb11996fff +_arpack.cpython-35-darwin.so (0) <B14B91C6-06EC-39F8-8D7B-8DF405D02557> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/sparse/linalg/eigen/arpack/_arpack.cpython-35-darwin.so
           0xb119b6000 -        0xb119d5ffb +_group_columns.cpython-35-darwin.so (0) <A247E79A-7932-36A1-BF47-D782D236FAFD> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_group_columns.cpython-35-darwin.so
           0xc119e7000 -        0xc11a01ff7 +_lbfgsb.cpython-35-darwin.so (0) <743C2394-4F9E-3C1A-97AE-EB7B338B0B13> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_lbfgsb.cpython-35-darwin.so
           0xc11a07000 -        0xc11a11ff7 +moduleTNC.cpython-35-darwin.so (0) <DDC1FCDA-863A-3538-A4FD-73EFE7591967> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/moduleTNC.cpython-35-darwin.so
           0xd11a14000 -        0xd11a2bff7 +_cobyla.cpython-35-darwin.so (0) <93F87D43-5A6E-3057-AF7B-81F71C764FC7> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_cobyla.cpython-35-darwin.so
           0xe11a30000 -        0xe11a47ff7 +_slsqp.cpython-35-darwin.so (0) <FAD78412-692A-3F4C-840E-90CB75E55AA9> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_slsqp.cpython-35-darwin.so
           0xf11a4c000 -        0xf11a67fe7 +_minpack.cpython-35-darwin.so (0) <52AD59B1-EC7D-31AA-95E6-CA96AC2C602A> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_minpack.cpython-35-darwin.so
           0xf11a6d000 -        0xf11a88fff +givens_elimination.cpython-35-darwin.so (0) <275F346F-9962-36E6-98C2-D3A9A5DCC79C> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_lsq/givens_elimination.cpython-35-darwin.so
           0xf11a99000 -        0xf11a9aff7 +_zeros.cpython-35-darwin.so (0) <9F1438A0-2624-3C7D-AD4E-3650094EBDF3> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_zeros.cpython-35-darwin.so
          0x1011a9d000 -       0x1011aa4fff +_nnls.cpython-35-darwin.so (0) <4241D068-E2C8-34DB-AD03-C319284553D6> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/optimize/_nnls.cpython-35-darwin.so
          0x1011ac3000 -       0x1011aecffb +pyexpat.cpython-35-darwin.so (0) <00CEDAA3-34FA-3A4D-94CB-A61F03D582D4> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/pyexpat.cpython-35-darwin.so
          0x1011aff000 -       0x1011b06fff +_elementtree.cpython-35-darwin.so (0) <9EA60666-DD67-30D8-8ECF-43C26FA49733> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/_elementtree.cpython-35-darwin.so
          0x1011d44000 -       0x1011d56ffb +libopenctm.dylib (0) <BE4F6EFB-146F-335B-BF9B-2DB67910444D> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libopenctm.dylib
          0x1011d5d000 -       0x1011d7eff7 +_nd_image.cpython-35-darwin.so (0) <8518EC04-E78D-34B5-80C3-8B707D0C7C4A> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/ndimage/_nd_image.cpython-35-darwin.so
          0x1112086000 -       0x11120b9fff +_fitpack.cpython-35-darwin.so (0) <4D2BEA51-7F3C-319D-942F-CE355D3F7827> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/interpolate/_fitpack.cpython-35-darwin.so
          0x12120c0000 -       0x121211cff7 +dfitpack.cpython-35-darwin.so (0) <86C98806-3A85-3FFC-B9EE-A733FEBA07DD> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/interpolate/dfitpack.cpython-35-darwin.so
          0x131212d000 -       0x131215cfff +_bspl.cpython-35-darwin.so (0) <D968F2B5-5705-3C68-8E0A-E657F6D0A22E> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/interpolate/_bspl.cpython-35-darwin.so
          0x1312175000 -       0x13121baff7 +_ppoly.cpython-35-darwin.so (0) <9B534E3E-F7BF-3997-AE0D-BA8240A885FB> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/interpolate/_ppoly.cpython-35-darwin.so
          0x13121d6000 -       0x1312217fff +interpnd.cpython-35-darwin.so (0) <731585AB-05B6-3C97-BFE1-8C0BFE2360FA> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/interpolate/interpnd.cpython-35-darwin.so
          0x1312234000 -       0x1312273ff3 +_ni_label.cpython-35-darwin.so (0) <24527225-771D-3FF9-AAC8-2E964C7B3B41> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/scipy/ndimage/_ni_label.cpython-35-darwin.so
          0x1312327000 -       0x131247ffff +libqcocoa.dylib (0) <14718E02-EB47-3C34-8D44-C45D746EA5EE> /Applications/Ultimaker Cura 2.app/Contents/Resources/platforms/libqcocoa.dylib
          0x13124c5000 -       0x13124f1ff3 +libQt5PrintSupport.5.dylib (0) <1B01ECC4-A087-3061-92D3-270D8D75E0E8> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5PrintSupport.5.dylib
          0x1313ec1000 -       0x1313ec2ffb +termios.cpython-35-darwin.so (0) <F97A4DEA-8151-3A1E-9959-B28A1F3F1FBA> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/termios.cpython-35-darwin.so
          0x13144ba000 -       0x13144bd047  libobjc-trampolines.dylib (781.2) <D4168201-48BA-3B42-A6EF-4341FF583962> /usr/lib/libobjc-trampolines.dylib
          0x13144d9000 -       0x13144dffff +libqgif.dylib (0) <66F0CA10-B286-313D-AB46-BB34BBC5C91A> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqgif.dylib
          0x13144e3000 -       0x13144eaffb +libqicns.dylib (0) <92CC28FE-7E95-3543-ABFE-6D0C6CF1FE38> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqicns.dylib
          0x13144ef000 -       0x13144f4fff +libqico.dylib (0) <ACA3A0CD-446B-363B-8BD5-EDC95CE1E990> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqico.dylib
          0x1314a36000 -       0x1314a48ff7 +PyQt5._QOpenGLFunctions_4_1_Core.so (0) <02B531B3-9441-3295-9D70-3BAE5546D972> /Applications/Ultimaker Cura 2.app/Contents/MacOS/lib/python3.5/PyQt5._QOpenGLFunctions_4_1_Core.so
          0x1314a54000 -       0x1314aa2fff +libqjpeg.dylib (0) <39A1F33E-BB59-3466-8735-92BC9C4A3EE7> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqjpeg.dylib
          0x1314aa8000 -       0x1314aacfff +libqmacjp2.dylib (0) <4104CA49-E4E8-3992-A381-D5929A2069E0> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqmacjp2.dylib
          0x1314ab0000 -       0x1314ab4ff7 +libqsvg.dylib (0) <0C9BDD24-8232-30AE-B437-E05E28D8FD4C> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqsvg.dylib
          0x1314ab8000 -       0x1314aeffff +libQt5Svg.5.dylib (0) <2ABA2D8F-1975-3A8D-8198-86988D05C101> /Applications/Ultimaker Cura 2.app/Contents/MacOS/libQt5Svg.5.dylib
          0x1314b0f000 -       0x1314b13ff7 +libqtga.dylib (0) <B3C294E1-BA4D-3C85-A323-2BBEBDD2D8F7> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqtga.dylib
          0x1314b17000 -       0x1314b76ff7 +libqtiff.dylib (0) <44982D5E-22E4-313B-854F-329C0FDFF8D2> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqtiff.dylib
          0x1314b7e000 -       0x1314b82ff3 +libqwbmp.dylib (0) <D449A615-D062-3950-99EB-D8BDE4F13A29> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqwbmp.dylib
          0x1314b86000 -       0x1314c0ffff +libqwebp.dylib (0) <FD5DDDE7-9862-34B4-BF35-D88A59804239> /Applications/Ultimaker Cura 2.app/Contents/Resources/imageformats/libqwebp.dylib
        0x7fff29f8d000 -     0x7fff29f8eff7  libCyrillicConverter.dylib (76) <F65E1E8A-2AA2-315C-BD92-238E2FC4994F> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
        0x7fff2d279000 -     0x7fff2d78afff  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (14.4.23 - 14.0.4) <67BD6396-F637-3897-86D5-EDF17EE5FAA4> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
        0x7fff2d78b000 -     0x7fff2d81effb  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (14.4.23 - 14.0.4) <391E8EF8-C60E-38DB-A798-0757263DB227> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
        0x7fff3133b000 -     0x7fff3133fffb  com.apple.agl (3.3.3 - AGL-3.3.3) <93797B81-445E-3D1B-9C0D-004A4E398F99> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
        0x7fff31726000 -     0x7fff31726fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <EEBE6680-1AAB-3192-AA7C-450537B07F27> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff31727000 -     0x7fff3173dfff  libCGInterfaces.dylib (524.2) <AF390BF7-8AF1-370D-ACC6-118889FA9ADB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
        0x7fff3173e000 -     0x7fff31da9fef  com.apple.vImage (8.1 - 524.2) <33B60C65-1E08-3490-ADC7-6C75AA3EA022> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff31daa000 -     0x7fff32013fff  libBLAS.dylib (1303.60.1) <0FE82DB0-0E71-300A-BF0B-70BF3478FE79> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff32014000 -     0x7fff32303ff7  libBNNS.dylib (144.40.3) <86C8FBB0-19D3-355B-99A3-6B094BB98C06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
        0x7fff32305000 -     0x7fff326aafff  libLAPACK.dylib (1303.60.1) <DCC36295-FF39-35A1-8DF1-1E8A714E2265> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff326ab000 -     0x7fff326c0ff8  libLinearAlgebra.dylib (1303.60.1) <0E47C269-832E-3B55-A6B6-855648BD206E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
        0x7fff326c1000 -     0x7fff326c6ff3  libQuadrature.dylib (7) <E0534024-B7E7-3382-830C-71E7BD9D3DE4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
        0x7fff326c7000 -     0x7fff32737fff  libSparse.dylib (103) <533DFAE8-8458-31F4-8AE2-B73C3869CED2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
        0x7fff32738000 -     0x7fff3274afef  libSparseBLAS.dylib (1303.60.1) <7CECC6DF-B4A8-38A7-B4E9-0CDDC6EA2510> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
        0x7fff3274b000 -     0x7fff32924ffb  libvDSP.dylib (735.40.1) <BD49856D-39CE-397F-A069-63B2F0D79529> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff32925000 -     0x7fff329e0fd7  libvMisc.dylib (735.40.1) <F3C565E5-8571-3E16-BC22-7687D1A756BD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff329e1000 -     0x7fff329e1fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A8B35A80-7217-38B1-8A20-E8B4F73124F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff329e2000 -     0x7fff32a41ffc  com.apple.Accounts (113 - 113) <C160B461-1DCD-3936-B8DE-72DD9B6473E1> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
        0x7fff32b87000 -     0x7fff33942fff  com.apple.AppKit (6.9 - 1894.30.142) <5A1752C0-67F4-3EDF-97DA-81AB42824B7B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff33992000 -     0x7fff33992fff  com.apple.ApplicationServices (48 - 50) <C1A1ED89-4F27-30E4-B53B-34062E971294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff33993000 -     0x7fff339fefff  com.apple.ApplicationServices.ATS (377 - 493.0.2.1) <99B0135E-8EB3-307E-86E3-04818B690B1A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff33a97000 -     0x7fff33ad5ff8  libFontRegistry.dylib (274.0.2.3) <E20402BC-8E91-359D-B724-BEAA24B75A92> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff33b30000 -     0x7fff33b5fff7  com.apple.ATSUI (1.0 - 1) <7956D5E1-879C-3A3F-990F-96B57EC0BFD3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
        0x7fff33b60000 -     0x7fff33b64ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <0805CEBA-9129-3EBC-85A5-32155C2F3D83> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
        0x7fff33bff000 -     0x7fff33c55ff2  com.apple.HIServices (1.22 - 674.1) <A65AE150-AB05-374A-8BC1-C35026566E8D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff33c56000 -     0x7fff33c64fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <3D4B4F59-6A83-302E-A460-5B903E9756EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff33c65000 -     0x7fff33caaff2  com.apple.print.framework.PrintCore (15 - 516) <1F202B29-4770-3D69-85D0-2B3F6982C45A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff33cab000 -     0x7fff33cb5fff  com.apple.QD (4.0 - 413) <E50C4B4E-F827-31A3-BACF-4ACEBF527F96> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff33cb6000 -     0x7fff33cc3ff0  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <4A1B8245-3735-361B-A456-FCE540D78707> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff33cc4000 -     0x7fff33da4ffa  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <7B308BA7-F08A-3E70-A494-F03A688AAA42> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff33da6000 -     0x7fff33da6fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <C3937FFF-1BCA-3A4F-B718-7D6CB4903907> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff3411c000 -     0x7fff344a8ff6  com.apple.CFNetwork (1121.1.2 - 1121.1.2) <4E539AC8-A995-3BA8-AAD6-31D97DAE734B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff34523000 -     0x7fff34523fff  com.apple.Carbon (160 - 162) <916D6D9E-3FE9-355C-913B-B44CAF35146D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff34524000 -     0x7fff34527ffb  com.apple.CommonPanels (1.2.6 - 101) <FB59B3A1-2FDC-34B4-A639-981135C97908> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff34528000 -     0x7fff3481cffb  com.apple.HIToolbox (2.1.1 - 994) <03BF3899-5DD5-3C1F-9DC6-B4C71CD656B6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff3481d000 -     0x7fff34820ff3  com.apple.help (1.3.8 - 68) <AF302261-AD99-3AD0-A684-CC24C87B6CED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff34821000 -     0x7fff34826ff7  com.apple.ImageCapture (9.0 - 1600.27.1) <1EFEBF06-C0DD-337E-805E-955A3A462395> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff34827000 -     0x7fff34827fff  com.apple.ink.framework (10.15 - 227) <E967D357-AF2E-338E-864D-CD94E87F6ECE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff34828000 -     0x7fff34842ff2  com.apple.openscripting (1.7 - 185.1) <EAE41338-2712-3774-944C-C946312EA562> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff34863000 -     0x7fff34863fff  com.apple.print.framework.Print (15 - 271) <26144B7F-F5C4-311D-A602-D014F0D4434D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff34864000 -     0x7fff34866ff7  com.apple.securityhi (9.0 - 55008) <E4E32973-55AB-38A9-A57D-50BCDF860646> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff34867000 -     0x7fff3486dff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A1ECC85-580E-3508-BA1B-93222EE431A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff34a16000 -     0x7fff34c01ff7  com.apple.ColorSync (4.13.0 - 3394.3) <61F27F92-1158-36A0-90D0-911A590F2904> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff34ef1000 -     0x7fff35400ffa  com.apple.audio.CoreAudio (5.0 - 5.0) <C1EE25DD-6880-3FFB-8C7D-4CBC10B41BD2> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff35453000 -     0x7fff3548aff0  com.apple.CoreBluetooth (1.0 - 1) <D1C334E4-E8C8-3FC4-B203-0555BA8C4932> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff3548b000 -     0x7fff3586dffe  com.apple.CoreData (120 - 977.1) <59E37E60-C008-3FE0-BA4B-CF344BF72B70> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff3586e000 -     0x7fff3597effe  com.apple.CoreDisplay (1.0 - 186.3.12) <4E34C576-C833-3E09-870A-13F4860337F5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff3597f000 -     0x7fff35dfffe7  com.apple.CoreFoundation (6.9 - 1674.114) <5810CC45-FB5D-3A78-861F-7BE03F9B2FDD> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff35e01000 -     0x7fff3647aff0  com.apple.CoreGraphics (2.0 - 1348.16) <48655F49-3617-33E6-B023-C2E031778FBF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff36488000 -     0x7fff367e5ff5  com.apple.CoreImage (15.0.0 - 920.9) <65109A99-EE48-3228-B73A-33044833A600> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff36d6f000 -     0x7fff36d6ffff  com.apple.CoreServices (1069.11 - 1069.11) <3BBDA17B-6F86-35F4-B785-AFA2A14B6F51> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff36d70000 -     0x7fff36df5fff  com.apple.AE (838 - 838) <877C7270-575A-3D5F-B768-4724037F025D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff36df6000 -     0x7fff370d7ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <DDC45E79-973C-3FB0-92EC-392A654179F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff370d8000 -     0x7fff37125ff5  com.apple.DictionaryServices (1.2 - 323.3.1) <A21D442C-E7B7-3A6C-BEEC-44B323AF9CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff37126000 -     0x7fff3712efff  com.apple.CoreServices.FSEvents (1268.60.1 - 1268.60.1) <8C772593-A2BA-33A7-BB43-49B9FCDD37CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
        0x7fff3712f000 -     0x7fff37368ff0  com.apple.LaunchServices (1069.11 - 1069.11) <7189EED9-9252-3030-AB32-6704AD9AEBAE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff37369000 -     0x7fff37401ff9  com.apple.Metadata (10.7.0 - 2075.7) <AECD1E1F-1C1B-3C42-9ACD-596980F145C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff37402000 -     0x7fff3742fff7  com.apple.CoreServices.OSServices (1069.11 - 1069.11) <67A2F664-DCA1-3FD6-B88E-CF020EA8C59D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff37430000 -     0x7fff37497fff  com.apple.SearchKit (1.4.1 - 1.4.1) <367BBFA7-F18C-34B6-B4C8-A244A125D5E0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff37498000 -     0x7fff374bcff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <EB8F2B1B-B736-373F-B28B-E4E6F33A00C0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
        0x7fff377e5000 -     0x7fff37999ffe  com.apple.CoreText (643.1.2.3 - 643.1.2.3) <D955D513-DC79-33A9-9E17-C8D86884DED1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff3799a000 -     0x7fff379defff  com.apple.CoreVideo (1.8 - 334.0) <1331FE6E-328D-35FF-BC55-5A2231B804A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff379df000 -     0x7fff37a6cff9  com.apple.framework.CoreWLAN (13.0 - 1455.3) <B1553A9E-1AC8-30D4-9B90-C7A719DBBF54> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff37d0c000 -     0x7fff37d12fff  com.apple.DiskArbitration (2.7 - 2.7) <5BE0B036-DEAB-3191-8D44-B489F4D39EE1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff37f06000 -     0x7fff3802cff6  com.apple.FileProvider (265.1 - 265.1) <B361EB77-4CD2-3231-B74F-F479FCD2DD23> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
        0x7fff38044000 -     0x7fff3840cffc  com.apple.Foundation (6.9 - 1674.114) <532BBAE7-F2BA-3779-94E0-BFEDF2D7AB38> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff38479000 -     0x7fff384c9ff7  com.apple.GSS (4.0 - 2.0) <5873DEB8-F186-3B53-BDFD-4E827B7EFFA2> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff38605000 -     0x7fff3871dff8  com.apple.Bluetooth (7.0.3 - 7.0.3f5) <B860F9C0-A082-386D-BCA7-4B2BC8384301> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff38784000 -     0x7fff38827ffb  com.apple.framework.IOKit (2.0.2 - 1726.80.1) <B63FE840-8E32-3429-A95D-AB466FE62104> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff38829000 -     0x7fff38839ffc  com.apple.IOSurface (269.6 - 269.6) <23D51648-9363-3696-9BF7-18F1B2AF621B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff388af000 -     0x7fff38a0cfee  com.apple.ImageIO.framework (3.3.0 - 1972.19) <484C67F4-2E4C-38F0-A2A5-A1CBE66558EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff38a0d000 -     0x7fff38a10fff  libGIF.dylib (1972.19) <2F8329F3-EE31-38AE-841A-D09BF48CAFF1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff38a11000 -     0x7fff38acbfe7  libJP2.dylib (1972.19) <3A695C63-A86D-364B-BDC9-D83D5078E371> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff38acc000 -     0x7fff38af0fef  libJPEG.dylib (1972.19) <4B2284A3-A308-3F54-AC7C-06FF2ED36ED2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff38d6e000 -     0x7fff38d88fef  libPng.dylib (1972.19) <DEF9EA12-460F-36B7-92BF-E96673E9470E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff38d89000 -     0x7fff38d8afff  libRadiance.dylib (1972.19) <11F23339-C944-30BE-AB22-B30D266F8CC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff38d8b000 -     0x7fff38dd4feb  libTIFF.dylib (1972.19) <74C59557-26A7-362A-BAC5-564EE6867F2A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff3a1f9000 -     0x7fff3a20bff3  com.apple.Kerberos (3.0 - 1) <DA356370-C1FA-3C23-9D77-5994EC7DC8C0> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff3a20c000 -     0x7fff3a20cfff  libHeimdalProxy.dylib (77) <CB20F0B8-EDC1-3592-8B2D-6AEF80BE080B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
        0x7fff3adbc000 -     0x7fff3ae7fff1  com.apple.Metal (212.2.4 - 212.2.4) <EF882FC9-08E4-36B3-9BAB-3FF5CD70364F> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff3ae9c000 -     0x7fff3aed8ff3  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <65A8E0C0-6266-3229-A58D-DA1E40068E25> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
        0x7fff3aed9000 -     0x7fff3af5ffe6  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <CA913DB0-C674-3AC6-AAD9-D28B84C58CF1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
        0x7fff3af60000 -     0x7fff3af84ff8  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <21FB637B-669C-3499-8BF3-1782B1484D52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
        0x7fff3af85000 -     0x7fff3af9afff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <0EE1E81D-0ABE-355D-B33B-5E5365C907C1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
        0x7fff3af9b000 -     0x7fff3b0faff4  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <850F399A-D538-3A36-A0AF-5EB20AA55062> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
        0x7fff3b0fb000 -     0x7fff3b149ff7  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <C71ECDCD-701A-3839-8627-0DF1A8906452> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
        0x7fff3b14a000 -     0x7fff3b14bff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <97194F33-650C-31C1-8A5A-56F48E5F5ECB> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
        0x7fff3c091000 -     0x7fff3c09dffe  com.apple.NetFS (6.0 - 4.0) <0B2088AE-C16D-3FC3-9445-4EDAD2D51686> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff3c09e000 -     0x7fff3c1e1ff6  com.apple.Network (1.0 - 1) <16D0A17C-1FA8-336C-A082-3AD2A3DB8E3C> /System/Library/Frameworks/Network.framework/Versions/A/Network
        0x7fff3ec01000 -     0x7fff3ec09fff  libcldcpuengine.dylib (2.12.7) <C56327E2-20A5-3B6E-9B77-601E02E6DC4D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff3ec0a000 -     0x7fff3ec62ff7  com.apple.opencl (3.5 - 3.5) <2B78F795-7131-3AAC-A2FB-FF01CB4A386D> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff3ec63000 -     0x7fff3ec7ffff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <FF068FF7-C136-3A71-AD1F-B5170A918423> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff3ec80000 -     0x7fff3ec8bff7  com.apple.OpenDirectory (10.15 - 220.40.1) <9448EC8E-8B76-3142-9540-C0752529762A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff3f5e6000 -     0x7fff3f5e8fff  libCVMSPluginSupport.dylib (17.10.22) <87C47A23-D8E9-3AE3-AADF-0DE1FF03905E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff3f5e9000 -     0x7fff3f5eefff  libCoreFSCache.dylib (176.10) <E5C4E721-5BD3-350D-8FD2-12397CD1858D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff3f5ef000 -     0x7fff3f5f3fff  libCoreVMClient.dylib (176.10) <35078399-3429-3EF5-AA29-C7E6CDB0F5FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff3f5f4000 -     0x7fff3f5fcff7  libGFXShared.dylib (17.10.22) <2E8AF2C7-2BA8-3385-B7F5-F4E1234B5A8A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff3f5fd000 -     0x7fff3f607fff  libGL.dylib (17.10.22) <0EDD0D07-1CDD-3E35-8CAB-EDD65862E321> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff3f608000 -     0x7fff3f63dfff  libGLImage.dylib (17.10.22) <86F7497C-6178-3E25-8BAD-9882681EAC84> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff3f63e000 -     0x7fff3f7d0ff7  libGLProgrammability.dylib (17.10.22) <A32F3C25-33DE-33E3-BF78-316259A5BA1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
        0x7fff3f7d1000 -     0x7fff3f80dfff  libGLU.dylib (17.10.22) <ECEA64DF-30EC-3709-9EED-C9970BC31DB3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff4023d000 -     0x7fff4024cff7  com.apple.opengl (17.10.22 - 17.10.22) <9530427D-0AE4-3F7D-B036-73FD32DDAD77> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff4024d000 -     0x7fff403c6ff7  GLEngine (17.10.22) <2436E4A2-A77D-3DD6-879E-2E02B1B43812> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff403c7000 -     0x7fff403effff  GLRendererFloat (17.10.22) <EE63BD85-5651-3F19-A0BD-CAE0B4405645> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
        0x7fff41207000 -     0x7fff41486ff1  com.apple.QuartzCore (1.11 - 820.6) <5366D2D9-670F-3B9B-A1F2-9C44F7DFC8E8> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff41fd6000 -     0x7fff42328ffa  com.apple.security (7.0 - 59306.80.4) <FA5EBA16-2B2B-3105-8A17-C8624C4B3BB3> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff42329000 -     0x7fff423b2ff7  com.apple.securityfoundation (6.0 - 55236.60.1) <0129932D-89E5-3608-B22E-DB5F0B3C3DC4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff423e1000 -     0x7fff423e5ff0  com.apple.xpc.ServiceManagement (1.0 - 1) <2475707B-F909-33C4-AAB7-80DC8D2CB435> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff43178000 -     0x7fff431e2fff  com.apple.SystemConfiguration (1.19 - 1.19) <61B73150-6D87-3E2F-A935-B957425CC992> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff46f4d000 -     0x7fff47011fe7  com.apple.APFS (1412.81.1 - 1412.81.1) <7EC14196-E481-35C0-94F0-09E5B81AD3E5> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
        0x7fff48112000 -     0x7fff48113ff1  com.apple.AggregateDictionary (1.0 - 1) <4EA2428D-FFB2-372C-BC1C-821BE221E8D0> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
        0x7fff484a0000 -     0x7fff484bdffc  com.apple.AppContainer (4.0 - 448.60.2) <A862A822-AA47-35DB-94FE-20B91B7E5F4A> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff48512000 -     0x7fff48520ff7  com.apple.AppSandbox (4.0 - 448.60.2) <0F317402-65DC-3D99-91BD-BA3F06B60517> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
        0x7fff489af000 -     0x7fff489d3ff3  com.apple.framework.Apple80211 (13.0 - 1460.1) <CB83A2CF-78A4-3E94-83C1-845037EB84FF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff48b09000 -     0x7fff48b18fef  com.apple.AppleFSCompression (119 - 1.0) <EEDA4040-1835-39A6-AC13-6CE35560C159> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff48c17000 -     0x7fff48c22ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <CBD0CBCD-C403-37FA-87C8-CCE0D4462452> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
        0x7fff48c64000 -     0x7fff48cacfff  com.apple.AppleJPEG (1.0 - 1) <42E71E36-8AFA-300C-8322-B6FE66E68441> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff4908c000 -     0x7fff490aefff  com.apple.applesauce (1.0 - 16.22) <E377E9B9-D02F-36BF-A012-587D55C814F7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
        0x7fff4916e000 -     0x7fff49171ffb  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <ED587319-ACF9-385F-A8BB-E74E61054FA6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff4920b000 -     0x7fff4921aff9  com.apple.AssertionServices (1.0 - 223.60.4) <24DF3272-5AE3-3E7B-AECC-5D3E1D1AA303> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
        0x7fff49dae000 -     0x7fff49febff7  com.apple.audio.AudioToolboxCore (1.0 - 1104.33) <0DB5EC73-CEEB-3971-B9C8-5263788DEBEC> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
        0x7fff49fec000 -     0x7fff4a105ff4  com.apple.AuthKit (1.0 - 1) <5B790973-7E89-3D7B-B1C9-56D3A65038CB> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
        0x7fff4a2c0000 -     0x7fff4a2c9ff3  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <D0F2851A-521F-335A-B7C4-B1E39BB42DD7> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
        0x7fff4a2ca000 -     0x7fff4a36bff8  com.apple.backup.framework (1.11.2 - 1298.2.10) <B4C73BEC-CEF3-3C18-AF66-C5BEAAB51AD8> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff4a36c000 -     0x7fff4a3edffd  com.apple.BaseBoard (464.1 - 464.1) <3F887960-21C3-3CB2-9DF2-59CA3DB64EB1> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
        0x7fff4a4ef000 -     0x7fff4a52bfff  com.apple.bom (14.0 - 219.2) <06E2ABAD-08EC-3EF5-8C02-38CF3C43C181> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff4b0b1000 -     0x7fff4b100fff  com.apple.ChunkingLibrary (302 - 302) <9FA43C86-7BC1-3CC3-A4CE-74A455CD7709> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff4bfc0000 -     0x7fff4bfd1fff  com.apple.CommonAuth (4.0 - 2.0) <6B36BE24-8D8B-3EE9-88BA-945B67F3AB6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff4bfe5000 -     0x7fff4bffcfff  com.apple.commonutilities (8.0 - 900) <7FADB6A2-AC75-329A-B4F8-D3A3350B02E9> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
        0x7fff4cb1a000 -     0x7fff4cb39ff0  com.apple.analyticsd (1.0 - 1) <74ED98BB-5B98-35A9-B6A4-02662EACE8BB> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
        0x7fff4d090000 -     0x7fff4d0a0ff3  com.apple.CoreEmoji (1.0 - 107) <544182E2-893F-3975-AA70-26ADC637B3F1> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
        0x7fff4d6f4000 -     0x7fff4d75eff0  com.apple.CoreNLP (1.0 - 213) <287973D6-1807-3A81-8F57-7BB39209F6C0> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
        0x7fff4dbd0000 -     0x7fff4dbd8ff0  com.apple.CorePhoneNumbers (1.0 - 1) <7DC06F8E-A897-38EE-B6E3-721C034F6067> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
        0x7fff4e325000 -     0x7fff4e348ff7  com.apple.CoreSVG (1.0 - 129) <7254CEB9-8A9C-3E02-A76D-CF858A5D87D5> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
        0x7fff4e349000 -     0x7fff4e37cff7  com.apple.CoreServicesInternal (446.6 - 446.6) <0CCCC36C-E33F-3DF8-B5E8-E1437F242933> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff4e37d000 -     0x7fff4e3abff7  com.apple.CSStore (1069.11 - 1069.11) <26602CC8-0080-3E85-A588-79CEF78D21E5> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
        0x7fff4e8b9000 -     0x7fff4e940fff  com.apple.CoreSymbolication (11.0 - 64509.98.1) <A44F2BDD-D8BA-36B7-97B3-CF4C77C2EA71> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff4e9d8000 -     0x7fff4eb04ff4  com.apple.coreui (2.1 - 608.3) <F909B4FA-2D2D-3142-B539-C0CF4A77D07A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff4eb05000 -     0x7fff4eca0ff6  com.apple.CoreUtils (6.1 - 610.19) <C1BEC3C0-C2D7-3333-A89C-7C0216DFFFA6> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
        0x7fff4edd5000 -     0x7fff4ede8ff1  com.apple.CrashReporterSupport (10.13 - 15011.2) <1BFBE272-C431-31BD-9E4F-3F31F680A247> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff4f052000 -     0x7fff4f064ffc  com.apple.framework.DFRFoundation (1.0 - 252) <C6C87C6D-7FBC-3501-8614-2050FDA0BBC3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
        0x7fff4f065000 -     0x7fff4f06afff  com.apple.DSExternalDisplay (3.1 - 380) <D8858746-3C00-3718-BC01-F511FA379A06> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
        0x7fff4f0d3000 -     0x7fff4f14eff8  com.apple.datadetectorscore (8.0 - 659) <4815229E-A03D-3F73-AAD7-D87789DD23EC> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff4f19a000 -     0x7fff4f1d8ff0  com.apple.DebugSymbols (194 - 194) <C0388FF0-F6A7-35C8-A274-D8B6AE52241D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff4f1d9000 -     0x7fff4f336ffe  com.apple.desktopservices (1.14.3 - 1281.3.2) <C476CE78-AECF-3D4E-BBF4-EB1A5F57B7AC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff50b62000 -     0x7fff50f7dff9  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <0255512B-C869-3DE7-9240-6506D5CC8284> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff515e1000 -     0x7fff51718ffc  libFontParser.dylib (277.2.1.2) <24CC0EED-DC94-3803-AA19-52A329DAFBF5> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
        0x7fff51719000 -     0x7fff5174dfff  libTrueTypeScaler.dylib (277.2.1.2) <9FD7CA8F-ED51-3B33-924C-26577FECC147> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
        0x7fff517b2000 -     0x7fff517c2ff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <4BD1C9D8-DF67-3CE6-B801-6785C218986E> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
        0x7fff54c87000 -     0x7fff54c88fff  libmetal_timestamp.dylib (902.11.1) <9FD477BF-E034-3D0D-970E-FD8BF83D97F4> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
        0x7fff56323000 -     0x7fff5632eff7  libGPUSupportMercury.dylib (17.10.22) <0ACD75CE-10B0-3759-B29D-4087BF2B7386> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
        0x7fff5632f000 -     0x7fff56335fff  com.apple.GPUWrangler (4.7.2 - 4.7.2) <BF17B917-2B63-37C5-9030-B14F282723B2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
        0x7fff56653000 -     0x7fff56679ffb  com.apple.GenerationalStorage (2.0 - 313) <420F07C2-AB4D-3585-BA3E-380739320932> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff5779d000 -     0x7fff577abffb  com.apple.GraphVisualizer (1.0 - 100.1) <94660F47-4A85-39D0-BA2B-B387D02477D9> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
        0x7fff5793e000 -     0x7fff579fbff4  com.apple.Heimdal (4.0 - 2.0) <C38A9368-4FAB-30DB-AFFC-9F0665DF2D9C> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff59b3c000 -     0x7fff59b44ffd  com.apple.IOAccelerator (438.3.1 - 438.3.1) <2E051DEF-89A9-36FD-ABF7-62795A7E7A11> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff59b47000 -     0x7fff59b5dff7  com.apple.IOPresentment (1.0 - 37) <4584C47E-5A31-372E-91DF-201141E3E41E> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
        0x7fff59ee7000 -     0x7fff59f32ff4  com.apple.IconServices (438.3 - 438.3) <D52BC60C-BA8C-3759-AA70-9F1B4325C85E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff5a0f0000 -     0x7fff5a0f6ffc  com.apple.InternationalSupport (1.0 - 45) <098000C3-AB40-3A6A-AE0B-6FC1B10A08AB> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
        0x7fff5a337000 -     0x7fff5a357ff6  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <9A1C0E52-1671-3687-9F61-B6F821440273> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
        0x7fff5a4af000 -     0x7fff5a57dff5  com.apple.LanguageModeling (1.0 - 215.1) <B47A62F3-7F45-3A84-A856-C674D4613261> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff5a57e000 -     0x7fff5a5c6ff7  com.apple.Lexicon-framework (1.0 - 72) <CD6D3F05-0647-348D-AED0-9566F968A954> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
        0x7fff5a5cd000 -     0x7fff5a5d1ff2  com.apple.LinguisticData (1.0 - 353.6.1) <91C3132C-EB52-32D6-9009-DE4B207ACE72> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
        0x7fff5b92c000 -     0x7fff5b978fff  com.apple.spotlight.metadata.utilities (1.0 - 2075.7) <F7FA0F68-7E46-3461-9DA6-C55FBB85C799> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
        0x7fff5b979000 -     0x7fff5ba47ffd  com.apple.gpusw.MetalTools (1.0 - 1) <9E8CB894-AD09-3264-B013-CBCF31105286> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
        0x7fff5bc77000 -     0x7fff5bc95ff7  com.apple.MobileKeyBag (2.0 - 1.0) <F2EDE53D-AE96-356E-B8D2-455FF24D3341> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
        0x7fff5befc000 -     0x7fff5bf2cfff  com.apple.MultitouchSupport.framework (3430.1 - 3430.1) <969DA9DA-B08A-3D53-960C-024AEA3E0AB2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff5c42c000 -     0x7fff5c436fff  com.apple.NetAuth (6.2 - 6.2) <A400CD55-B3EA-371A-8BAB-FDDA87660AE4> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff5ce27000 -     0x7fff5ce73ff7  com.apple.OTSVG (1.0 - 643.1.2.3) <7F19E0AF-9E41-32DE-A19B-37D1C131B230> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
        0x7fff5e009000 -     0x7fff5e014ffe  com.apple.PerformanceAnalysis (1.243.1 - 243.1) <D33C31A5-AE17-3455-B33A-62EFBF5DF5E7> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff5e015000 -     0x7fff5e03dffb  com.apple.persistentconnection (1.0 - 1.0) <7474CCC1-A27A-38FC-B9D6-BAB08AD736DE> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
        0x7fff6099b000 -     0x7fff609b4fff  com.apple.ProtocolBuffer (1 - 274.20.7.15.1) <3322B8EE-991A-30C2-BCA1-B81E7DDE7B6B> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff60dbd000 -     0x7fff60de6ff9  com.apple.RemoteViewServices (2.0 - 148) <34347997-F06E-3000-B336-093A2B055E31> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff60f4c000 -     0x7fff60f87ff4  com.apple.RunningBoardServices (1.0 - 223.60.4) <111A73BB-C1CD-35B8-AEFD-98CA52B1514F> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
        0x7fff628d2000 -     0x7fff628d5ff9  com.apple.SecCodeWrapper (4.0 - 448.60.2) <C6EBD591-8132-31FB-991A-368BA9B7444D> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff62a48000 -     0x7fff62b6cff4  com.apple.Sharing (1506.6 - 1506.6) <4FA735A0-4BDB-384C-B04D-7C2EB3DEDCFB> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff63b84000 -     0x7fff63e7cffa  com.apple.SkyLight (1.600.0 - 450.1) <9B2718F3-27FC-319C-98DD-881FD7C742AB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff646c4000 -     0x7fff646d2fff  com.apple.SpeechRecognitionCore (6.0.91 - 6.0.91) <10EBEF24-6C75-3E91-B99B-DC1BCD498D8A> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
        0x7fff64eff000 -     0x7fff64f08ff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.60.1) <921F5137-CD53-35A9-92EA-1A3C412E4C51> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
        0x7fff651be000 -     0x7fff651ceff3  com.apple.TCC (1.0 - 1) <A8308EDB-9AF7-3B6B-AAC3-143F91F58F1D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff656c3000 -     0x7fff6578aff4  com.apple.TextureIO (3.10.9 - 3.10.9) <CFA1BB98-DECC-30CB-B923-EFF42B904226> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
        0x7fff65907000 -     0x7fff65908fff  com.apple.TrustEvaluationAgent (2.0 - 33) <FB6537B0-DA74-3FB7-B364-60828A9CF7E9> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff665e1000 -     0x7fff6683bff2  com.apple.UIFoundation (1.0 - 660) <A48A9528-88BA-3883-9FD9-3150568D7BDA> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff6742f000 -     0x7fff6744ffff  com.apple.UserManagement (1.0 - 1) <6B41CDA7-B382-36D9-8435-F355DE42C596> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
        0x7fff68205000 -     0x7fff682f0ffe  com.apple.ViewBridge (464.1 - 464.1) <AAFB0B7B-8A94-3664-8FEA-A616CD8BFDDD> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff68496000 -     0x7fff68497fff  com.apple.WatchdogClient.framework (1.0 - 67.60.1) <D998CF4B-D757-3B33-A498-5C4259CE882B> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
        0x7fff69074000 -     0x7fff69077ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 15700) <09FE38EC-8B8D-385B-BBF9-48F1133A8E50> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
        0x7fff690f0000 -     0x7fff690feff5  com.apple.audio.caulk (1.0 - 32.3) <E436DBA4-321E-3C6B-80F3-AE06E44D05C8> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
        0x7fff6943f000 -     0x7fff69441ff3  com.apple.loginsupport (1.0 - 1) <F2EC9213-901A-3657-A36A-DFD80BD8ABBC> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
        0x7fff69442000 -     0x7fff69455ffd  com.apple.login (3.0 - 3.0) <9892EED5-B5C4-3E2F-B89B-7CB0ACECA8B1> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
        0x7fff69765000 -     0x7fff6979bffa  libAudioToolboxUtility.dylib (1104.33) <5426E64E-18E2-33E0-A9A8-BD8D449BA463> /usr/lib/libAudioToolboxUtility.dylib
        0x7fff697a2000 -     0x7fff697d7ff7  libCRFSuite.dylib (48) <31D98527-9972-3A4B-9868-C9394FAF742E> /usr/lib/libCRFSuite.dylib
        0x7fff697da000 -     0x7fff697e4ff3  libChineseTokenizer.dylib (34) <9E2B02B0-32A5-3245-AC50-F6BEEC34FCEC> /usr/lib/libChineseTokenizer.dylib
        0x7fff69871000 -     0x7fff69873ff7  libDiagnosticMessagesClient.dylib (112) <45E85899-039F-3B99-8789-F497DD9916C2> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff698b8000 -     0x7fff69a6fff3  libFosl_dynamic.dylib (100.4) <84A5F946-01EE-3740-BD2F-4C2A6B1FE82B> /usr/lib/libFosl_dynamic.dylib
        0x7fff69a96000 -     0x7fff69a9cff3  libIOReport.dylib (54) <F60AF538-9EE4-3E10-A289-A015257841B6> /usr/lib/libIOReport.dylib
        0x7fff69b7c000 -     0x7fff69b83fff  libMatch.1.dylib (36) <861F4202-5A25-3CA3-98AE-024F91EA95F5> /usr/lib/libMatch.1.dylib
        0x7fff69bb3000 -     0x7fff69bd2fff  libMobileGestalt.dylib (826.80.1) <107E3D8D-CCCD-32F4-B858-3F355126F733> /usr/lib/libMobileGestalt.dylib
        0x7fff69d39000 -     0x7fff69d3aff3  libSystem.B.dylib (1281) <A2C26908-8802-3CA7-8B74-ED4A74AA152C> /usr/lib/libSystem.B.dylib
        0x7fff69dc9000 -     0x7fff69dcafff  libThaiTokenizer.dylib (3) <9E5B4E50-E982-387C-AA2F-BB43867322ED> /usr/lib/libThaiTokenizer.dylib
        0x7fff69de2000 -     0x7fff69df8fff  libapple_nghttp2.dylib (1.39.2) <C79E1B79-0BBE-311F-A177-6879D5C4D991> /usr/lib/libapple_nghttp2.dylib
        0x7fff69e2d000 -     0x7fff69e9fff7  libarchive.2.dylib (72.40.2) <1AE0592D-8451-30D1-AEE8-3F39F46D9DD4> /usr/lib/libarchive.2.dylib
        0x7fff69ea0000 -     0x7fff69f36fc5  libate.dylib (2.0.9) <DE07BAA8-3ABB-317B-BF53-E7B867069B51> /usr/lib/libate.dylib
        0x7fff69f3a000 -     0x7fff69f3aff3  libauto.dylib (187) <71A48A59-FE0E-3D86-A219-B79DAF7CF9DD> /usr/lib/libauto.dylib
        0x7fff6a001000 -     0x7fff6a011ff3  libbsm.0.dylib (60) <5EBEA671-D25B-3425-AC2B-70C2760B8B94> /usr/lib/libbsm.0.dylib
        0x7fff6a012000 -     0x7fff6a01efff  libbz2.1.0.dylib (44) <FA7CE29A-2FE3-3107-8693-5D33D5B7E11F> /usr/lib/libbz2.1.0.dylib
        0x7fff6a01f000 -     0x7fff6a072ff7  libc++.1.dylib (800.7) <1D0CB627-8A78-329F-A679-1B5248FF4C59> /usr/lib/libc++.1.dylib
        0x7fff6a073000 -     0x7fff6a087fff  libc++abi.dylib (800.7) <7AF668FB-901D-3F45-BA0D-710A235A8D1F> /usr/lib/libc++abi.dylib
        0x7fff6a088000 -     0x7fff6a088ffb  libcharset.1.dylib (59) <56F66234-104F-3494-B336-598800CF3F71> /usr/lib/libcharset.1.dylib
        0x7fff6a089000 -     0x7fff6a09affb  libcmph.dylib (8) <9B9AB2BA-75FB-3B70-AAE4-E32B06CF9D69> /usr/lib/libcmph.dylib
        0x7fff6a09b000 -     0x7fff6a0b2fe7  libcompression.dylib (87) <A252D9B2-0D88-3345-94DC-E5D7C8245985> /usr/lib/libcompression.dylib
        0x7fff6a382000 -     0x7fff6a398ff7  libcoretls.dylib (167) <6D32CE15-591C-39AD-9A3E-0C2FFC03C3C1> /usr/lib/libcoretls.dylib
        0x7fff6a399000 -     0x7fff6a39afff  libcoretls_cfhelpers.dylib (167) <3CE60FA9-98FC-3EE0-B398-177F3CAA850D> /usr/lib/libcoretls_cfhelpers.dylib
        0x7fff6a53d000 -     0x7fff6a637fff  libcrypto.35.dylib (47.11.1) <0CE4FEA8-08AE-31AC-99B8-8FF9B4947DD7> /usr/lib/libcrypto.35.dylib
        0x7fff6a958000 -     0x7fff6a9b7fff  libcups.2.dylib (483.2) <440F82E8-646B-337D-A60E-976FF2C901ED> /usr/lib/libcups.2.dylib
        0x7fff6aac3000 -     0x7fff6aac3fff  libenergytrace.dylib (21) <8E5C9BB2-14F4-37DF-AAE7-8130EBF466A3> /usr/lib/libenergytrace.dylib
        0x7fff6aac4000 -     0x7fff6aaddff7  libexpat.1.dylib (19.60.2) <641F502C-FF8F-3C15-A262-F92F94D7C7E3> /usr/lib/libexpat.1.dylib
        0x7fff6aaeb000 -     0x7fff6aaedfff  libfakelink.dylib (149) <7296A5B3-EE44-34E6-810A-2A12C2D3EF68> /usr/lib/libfakelink.dylib
        0x7fff6aafc000 -     0x7fff6ab01fff  libgermantok.dylib (24) <7B3FFFFB-5E34-3940-8E0A-B64A2DE42E68> /usr/lib/libgermantok.dylib
        0x7fff6ab02000 -     0x7fff6ab0bff7  libheimdal-asn1.dylib (564.60.2) <C37C4E10-F1D3-3B62-BDDF-7DBC611ACEC6> /usr/lib/libheimdal-asn1.dylib
        0x7fff6ab0c000 -     0x7fff6abfcff7  libiconv.2.dylib (59) <30414773-5E42-3976-B7C3-9BB8883792EE> /usr/lib/libiconv.2.dylib
        0x7fff6abfd000 -     0x7fff6ae55ff7  libicucore.A.dylib (64252.0.1) <0F9294A7-6EC0-3279-BF92-3233C89DFA0A> /usr/lib/libicucore.A.dylib
        0x7fff6ae6f000 -     0x7fff6ae70fff  liblangid.dylib (133) <EDF945D6-A37D-3DEB-B956-B4745269603D> /usr/lib/liblangid.dylib
        0x7fff6ae71000 -     0x7fff6ae89ff3  liblzma.5.dylib (16) <F75FB525-C702-3A7E-9239-28D57E677DD5> /usr/lib/liblzma.5.dylib
        0x7fff6aea1000 -     0x7fff6af48fff  libmecab.dylib (883.1.1) <A2C923A6-D955-3FF1-82AE-7E54947F9566> /usr/lib/libmecab.dylib
        0x7fff6af49000 -     0x7fff6b1abfe1  libmecabra.dylib (883.1.1) <971A30D4-1C27-3DD1-AACF-8337AE059F70> /usr/lib/libmecabra.dylib
        0x7fff6b51b000 -     0x7fff6b54aff7  libncurses.5.4.dylib (57) <8882C63D-A0EC-3B10-8DD9-FD6419FB7C80> /usr/lib/libncurses.5.4.dylib
        0x7fff6b679000 -     0x7fff6baefff7  libnetwork.dylib (1880.60.5) <8B4092C3-9F1C-34C3-A73D-A2228C345831> /usr/lib/libnetwork.dylib
        0x7fff6bb8e000 -     0x7fff6bbbffc6  libobjc.A.dylib (781.2) <7B72F50A-5381-36D7-A616-65D3EA9748A5> /usr/lib/libobjc.A.dylib
        0x7fff6bbd2000 -     0x7fff6bbd6fff  libpam.2.dylib (25) <55302451-C2B2-3DB4-9092-B84E236104DA> /usr/lib/libpam.2.dylib
        0x7fff6bbd9000 -     0x7fff6bc0fff7  libpcap.A.dylib (89.60.2) <FD167BF3-6984-36E1-9D93-E8B98E3E64A1> /usr/lib/libpcap.A.dylib
        0x7fff6bc91000 -     0x7fff6bca9ff7  libresolv.9.dylib (67.40.1) <F363FB44-7C6D-3BC6-A897-639C74F9C97B> /usr/lib/libresolv.9.dylib
        0x7fff6bcab000 -     0x7fff6bceffff  libsandbox.1.dylib (1217.80.1) <87099525-DB29-3530-87A6-BD484B56E97C> /usr/lib/libsandbox.1.dylib
        0x7fff6bd05000 -     0x7fff6bef2ff7  libsqlite3.dylib (308.4) <448E300F-0157-3AEA-B199-0DFA914B1547> /usr/lib/libsqlite3.dylib
        0x7fff6c0e8000 -     0x7fff6c143ff8  libusrtcp.dylib (1880.60.5) <F6FC3EF8-2939-3067-B08E-B2E615DBF0D7> /usr/lib/libusrtcp.dylib
        0x7fff6c144000 -     0x7fff6c147ffb  libutil.dylib (57) <6CB26E6D-AD27-3FA8-8A30-4AFC3A2AE3F9> /usr/lib/libutil.dylib
        0x7fff6c148000 -     0x7fff6c155fff  libxar.1.dylib (420) <317EA455-78EE-35A4-B63F-D85993B8697C> /usr/lib/libxar.1.dylib
        0x7fff6c15b000 -     0x7fff6c23dff7  libxml2.2.dylib (32.14) <4F4EB304-2AA5-3E5F-AB24-F645E0D16EFC> /usr/lib/libxml2.2.dylib
        0x7fff6c241000 -     0x7fff6c269fff  libxslt.1.dylib (16.7) <E9BBE609-BA57-368D-95D7-ACA3A8C1AE8B> /usr/lib/libxslt.1.dylib
        0x7fff6c26a000 -     0x7fff6c27cffb  libz.1.dylib (76) <52250917-039C-3B46-8011-497FEACF3550> /usr/lib/libz.1.dylib
        0x7fff6cce0000 -     0x7fff6cce5ff3  libcache.dylib (83) <11C19883-6F99-390D-AF2A-A85A99DDFC48> /usr/lib/system/libcache.dylib
        0x7fff6cce6000 -     0x7fff6ccf1fff  libcommonCrypto.dylib (60165) <FEE99884-61F0-3332-852B-B0BB8EFF2288> /usr/lib/system/libcommonCrypto.dylib
        0x7fff6ccf2000 -     0x7fff6ccf9fff  libcompiler_rt.dylib (101.2) <D7367E6D-A27D-3209-A3DB-A6F44582E502> /usr/lib/system/libcompiler_rt.dylib
        0x7fff6ccfa000 -     0x7fff6cd03fff  libcopyfile.dylib (166.40.1) <91670D15-CB30-3277-8AA9-9A299CEAAE27> /usr/lib/system/libcopyfile.dylib
        0x7fff6cd04000 -     0x7fff6cd9bfdb  libcorecrypto.dylib (866.80.2) <3B110D82-B403-31E8-8109-8BBC79C928CE> /usr/lib/system/libcorecrypto.dylib
        0x7fff6ceb2000 -     0x7fff6cef3ff0  libdispatch.dylib (1173.60.1) <5EF42E98-AD0D-3FAE-ABD4-46D791B8343F> /usr/lib/system/libdispatch.dylib
        0x7fff6cef4000 -     0x7fff6cf29ff7  libdyld.dylib (733.8) <8B0DFE8A-42CF-32C8-B121-83C22BF25F69> /usr/lib/system/libdyld.dylib
        0x7fff6cf2a000 -     0x7fff6cf2affb  libkeymgr.dylib (30) <7DADC026-70A8-390F-95AF-F3F345760F24> /usr/lib/system/libkeymgr.dylib
        0x7fff6cf2b000 -     0x7fff6cf37ff7  libkxld.dylib (6153.81.5) <7572CC82-E7E1-3C38-825F-9B34E2EADAD0> /usr/lib/system/libkxld.dylib
        0x7fff6cf38000 -     0x7fff6cf38ff7  liblaunch.dylib (1738.80.8) <C4EA8803-E506-3514-9839-9BBECC819953> /usr/lib/system/liblaunch.dylib
        0x7fff6cf39000 -     0x7fff6cf3eff7  libmacho.dylib (949.0.1) <395ABE7C-D2B1-343D-A451-9CEA98FDC12E> /usr/lib/system/libmacho.dylib
        0x7fff6cf3f000 -     0x7fff6cf41ff7  libquarantine.dylib (110.40.3) <560961FC-1FEF-3F07-8406-17A36558870E> /usr/lib/system/libquarantine.dylib
        0x7fff6cf42000 -     0x7fff6cf43ff7  libremovefile.dylib (48) <E99833DE-CB1D-31AB-A948-2739AF503599> /usr/lib/system/libremovefile.dylib
        0x7fff6cf44000 -     0x7fff6cf5bfff  libsystem_asl.dylib (377.60.2) <21A259BC-F892-34EB-9A67-11232AD8913A> /usr/lib/system/libsystem_asl.dylib
        0x7fff6cf5c000 -     0x7fff6cf5cfff  libsystem_blocks.dylib (74) <8B23F806-8153-3163-B5D8-2C3327E211D8> /usr/lib/system/libsystem_blocks.dylib
        0x7fff6cf5d000 -     0x7fff6cfe4ff7  libsystem_c.dylib (1353.60.8) <99202CC3-2E27-3680-A8FF-5C516C485E90> /usr/lib/system/libsystem_c.dylib
        0x7fff6cfe5000 -     0x7fff6cfe8ffb  libsystem_configuration.dylib (1061.80.3) <8A149700-51AA-3205-A9D4-FF2A7BFC5412> /usr/lib/system/libsystem_configuration.dylib
        0x7fff6cfe9000 -     0x7fff6cfecff7  libsystem_coreservices.dylib (114) <CCC076FA-310D-3FC9-950D-41E0F8DDA5D2> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff6cfed000 -     0x7fff6cff5fff  libsystem_darwin.dylib (1353.60.8) <31ACD3CC-6DD9-3F2E-B163-9342BE1D0AB0> /usr/lib/system/libsystem_darwin.dylib
        0x7fff6cff6000 -     0x7fff6cffdffb  libsystem_dnssd.dylib (1096.60.2) <BEBB815A-065A-365E-9701-8E05A8CF2040> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff6cffe000 -     0x7fff6cfffffb  libsystem_featureflags.dylib (17) <340AD606-7C39-3E6A-BAC3-EA1273FC27A4> /usr/lib/system/libsystem_featureflags.dylib
        0x7fff6d000000 -     0x7fff6d04dfff  libsystem_info.dylib (538) <B0EBAE05-01AD-3D8E-92CC-5704394FF94A> /usr/lib/system/libsystem_info.dylib
        0x7fff6d04e000 -     0x7fff6d07aff7  libsystem_kernel.dylib (6153.81.5) <23909F45-79C3-34C9-A28F-337915925E5E> /usr/lib/system/libsystem_kernel.dylib
        0x7fff6d07b000 -     0x7fff6d0c2fcf  libsystem_m.dylib (3178) <7D775039-51B8-356E-82D7-98449065518A> /usr/lib/system/libsystem_m.dylib
        0x7fff6d0c3000 -     0x7fff6d0eafff  libsystem_malloc.dylib (283.60.1) <00190446-C6A8-3EA6-92D1-850EA85C84CE> /usr/lib/system/libsystem_malloc.dylib
        0x7fff6d0eb000 -     0x7fff6d0f8ffb  libsystem_networkextension.dylib (1095.60.2) <1E7A59D0-BBCD-3CB0-8AD1-D442A1A5268E> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff6d0f9000 -     0x7fff6d102ff3  libsystem_notify.dylib (241) <AB3FAC47-A830-3158-8D99-DBC728CED1D6> /usr/lib/system/libsystem_notify.dylib
        0x7fff6d103000 -     0x7fff6d10cfef  libsystem_platform.dylib (220) <3DAFCC01-B768-3FFC-AC59-47AAE86BBEA1> /usr/lib/system/libsystem_platform.dylib
        0x7fff6d10d000 -     0x7fff6d117fff  libsystem_pthread.dylib (416.60.2) <AAF506F4-9455-3CC4-8E0B-6791E3C0993C> /usr/lib/system/libsystem_pthread.dylib
        0x7fff6d118000 -     0x7fff6d11cfff  libsystem_sandbox.dylib (1217.80.1) <C8F3841A-9364-3414-9E3F-9DE3D5FECF0C> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff6d11d000 -     0x7fff6d11ffff  libsystem_secinit.dylib (62.80.1) <32F36517-9A1C-3D30-85C8-611A2F5E2355> /usr/lib/system/libsystem_secinit.dylib
        0x7fff6d120000 -     0x7fff6d127ffb  libsystem_symptoms.dylib (1238.60.1) <2EDF9CE8-4091-30A8-B125-0F25E579694A> /usr/lib/system/libsystem_symptoms.dylib
        0x7fff6d128000 -     0x7fff6d13eff2  libsystem_trace.dylib (1147.80.3) <AE11B1AC-352A-37F0-BCA9-055609070104> /usr/lib/system/libsystem_trace.dylib
        0x7fff6d140000 -     0x7fff6d145ffb  libunwind.dylib (35.4) <E867ACDE-EADE-3C91-A2A4-0C401788FD47> /usr/lib/system/libunwind.dylib
        0x7fff6d146000 -     0x7fff6d17bffe  libxpc.dylib (1738.80.8) <51E3E807-9133-3605-BB5F-D59ED6404ABF> /usr/lib/system/libxpc.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 1
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 22050
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=658.5M resident=0K(0%) swapped_out_or_unallocated=658.5M(100%)
    Writable regions: Total=73.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=73.7G(100%)
                                    VIRTUAL   REGION
    REGION TYPE                        SIZE    COUNT (non-coalesced)
    Accelerate framework               128K        1
    Activity Tracing                   256K        1
    CG backing stores                  736K        3
    CG image                            80K        3
    CoreAnimation                       20K        4
    CoreGraphics                         8K        1
    CoreImage                            8K        2
    CoreUI image data                  136K        3
    Foundation                           4K        1
    Kernel Alloc Once                    8K        1
    MALLOC                             1.2G      110
    MALLOC guard page                   32K        8
    MALLOC_LARGE (reserved)            512K        2         reserved VM address space (unallocated)
    MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
    Memory Tag 242                      12K        1
    STACK GUARD                       56.0M       12
    Stack                             40.6M       12
    VM_ALLOCATE                        168K       16
    VM_ALLOCATE (reserved)            96.0M        1         reserved VM address space (unallocated)
    __DATA                            30.0M      431
    __DATA_CONST                        20K        1
    __FONT_DATA                          4K        1
    __GLSLBUILTINS                    5176K        1
    __LINKEDIT                       374.8M      129
    __OBJC_RO                         32.0M        1
    __OBJC_RW                         1780K        2
    __TEXT                           283.7M      403
    __UNICODE                          564K        1
    dylib (reserved)                  72.0G       18         reserved VM address space (unallocated)
    mapped file                      293.9M       47
    shared memory                      636K       15
    TOTAL                             74.8G     1233
    TOTAL, minus reserved VM space     2.3G     1233
    Model: iMac14,1, BootROM 141.0.0.0.0, 4 processors, Quad-Core Intel Core i5, 2,7 GHz, 8 GB, SMC 2.14f24
    Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343531533641465238412D50422020
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343531533641465238412D50422020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.77.106.3 AirPortDriverBrcmNIC-1440.1)
    Bluetooth: Version 7.0.3f5, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Ethernet, Ethernet, en0
    Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
    USB Device: USB 3.0 Bus
    USB Device: BRCM20702 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: FaceTime HD Camera (Built-in)
    Thunderbolt Bus: iMac, Apple Inc., 23.10
    Posted · Ultimaker Cura 4.5 now available
    14 minutes ago, gr5 said:
    @OI_3 please post the log.  A lot of people say cura is slow and it's often related to network issues and is often helped by disabling plugins related to printing over the network.  Are you saying it's slow or it doesn't launch at all or it launches but.... something?  Please define "does not run" with more details.
    On 3/18/2020 at 12:54 AM, thorsenrune said:
    HtRabbit
    I had that problem with other printers, not with UM5 so I think it depends on your machine. It has something to do with waiting for temperature to change. You have a standby temperature and an extrusion temperature M109.
       I think you are correct, it would be good if we could have it move to the tower before pausing so as not to scare us as it pauses right above the print.
    Honestly I have been struggeling a lot with the RepRap & Olivetti printers. And I just love my new UM5 because I don't fiddle anymore with these issues (knock on wood). I just print and thats the right direction of 3D printing.
    Rather than moving around I would suggest just a message on the display on what is going on (switching extruder waiting for temperature )
    Cheers
    Hello,
    I’m on Windows 10 professional 64bit and the last three times I’ve restarted my computer the next time I try to load Cura 4.5 it re-runs the new setup wizard and has wiped most of my settings.
    if I restore a backup ... I’m not sure what it actually restores because it looks like I’m mostly starting over from scratch.
    not sure if it’s a windows update problem ... I’m running current and with the way Microsoft likes to run fast and face plant lately ...
    thanks for your time,
    Bobby
    Sounds like your user data is getting wiped somehow. More details for this can be found here.
    Bug Processing jpg files Cura 4.5
    There appears to be a bug processing jpg files.    If I load a jpg file and leave all of the settings as the defaults it seems to behave as expected.  If I change  the value for "Base" to something that is larger than the value for "Height" it appears to get really confused.   This works fine in Cura 4.4.1.
    Can you please open an issue on github about this?
    Hello,
    I would like to know the page on which all the place holder variables are given for the Cura's settings. I want to make a few changes for my machine profile and then submit a pull request.
    Thanks
    Posted (edited) · Ultimaker Cura 4.5 now available
    See http://files.fieldofview.com/cura/Replacement_Patterns.html
    Most of that page parse the input from https://github.com/Ultimaker/Cura/blob/master/resources/definitions/fdmprinter.def.json into something more readable.
    Edited by ahoeben
    @ahoeben Thanks alot !
    4.6 is now in beta, find out more here:
    running Cura 4.2.1. when printing a layer head will pause mid layer the return back along its path, at the pause point leaves a small "ZIT". is this an ongoing problem or has it been fixed. Tried every thing..... except the solution.
    On 3/9/2020 at 12:33 AM, ChaosBlades said:
    hussainsail2002's solution causes cura to produce an invalid configuration issue and forces you to reset cura to defaults.
    To fix the Ender 3 disallowed areas issue go to...
    C:\Program Files\Ultimaker Cura\resources\definitions
    Find...
    creality_ender3.def.json
    Change (In Notepad++)...
            "machine_disallowed_areas": {
                "default_value": [
                  [[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]],
                  [[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]
    To...
                "default_value": [
    Save and restart Cura.
    Really thx,
    For Ender 3 Max, I've Add CR-10S5 and modify creality_cr10.def.json like this (Cura 4.11)
        "name": "Creality CR-10",
        "version": 2,
        "inherits": "creality_base",
        "overrides": {
            "machine_name": { "default_value": "Creality CR-10" },
            "machine_width": { "default_value": 300 },
            "machine_depth": { "default_value": 300 },
            "machine_height": { "default_value": 400 },
            "machine_head_with_fans_polygon": { "default_value": [
                    [-26, 34],
                    [-26, -32],
                    [32, -32],
                    [32, 34]
                "default_value": [
            "gantry_height": { "value": 25 }
        "metadata": {
            "quality_definition": "creality_base",
            "visible": true
    Edited by camarade35
    • Thanks 1
        • 10 replies
