Ok, I understand. I did't know the Cura Mesh Tool and it's great for this kind of problems.
Thanks a lot!
I've fixed the model and now pass the mesh tool, but still does not appear the holes. Attached versions with 1mm and 2mm holes.
Forget it, works fine: I had enabled the "Remove All Holes" option 😓
burtoogle 506
Hi @monkiki, it's hard to be sure without seeing your settings and model. Please do File -> Save and then attach the .3mf file to this thread. Thanks.
