I don't see the problem. Are you saying the hands fall over or fall off or something before it connects the hand to the arm? Is that the failure mode?
I would probably print this part on it's back. It's better to use as little Z space as possible. Usually the back of the model is what people pay less attention to so the worse quality of support attachment/removal might be best on the back of the print. You can use the cura tools on the left side - select the model, then select the rotation tool and rotate him onto his back.
Alternatively you could model supports in CAD - or some of the supports. Make those two "arm towers" much thicker. You could just download 2 cubes and add them and size them with the scale tool on the left.
gr5 2,331
Well don't use zhop - that only seems to work well with delta printers.
Here's a screenshot of what the poster is talking about.
