Saving print profiles before updating Cura
mayhem
Posted · Saving print profiles before updating Cura
I'm having an issue with Cura 4.0 opening. The splash screen loads then the program window pops up and just remains white and unresponsive. I've searched this issue an have tried compatibility mode, run as Admin, and deleting post 2015 versions of Microsoft visual C + +, none of which worked. I was going to try and uninstall and reinstall the current version, but I want to keep my profiles. Since I can't open the program, are they saved somewhere? Thanks for your help
    Posted (edited) · Saving print profiles before updating Cura
    Hello,
    in the marketplace, there are tools for updating for not to loose any confogurations. Install before upgrade (the actual version upgrade installs automatically). I don't need the versions 4.0-->4.1 and 4.1-->4.2: I uninstalled these manually.
    What i don't know: upgrading for many versions!
    -->You should leave the old version installed, only install the newest version. On my computer (mac) it works fine (-->rename the old version...).
    Edited by EberleAl
    Text improved, error correction
    4 minutes ago, mayhem said:
    I can't use Marketplace, because the program will not open
    Cura WILL NOT open
    Edited by mayhem
    Hello,
    I would try to install the next version (4.1); normally on my computer (OSX), it makes a copy of all preferences. Afterwards (if running) you should update at least to 4.3; -->4.4 and 4.5 have issues with holes...
    --> I have simultanely installed 4.3, 4.4.1, 4.5 and can use the version I need!
    good luck
    Edited by EberleAl
    Seems that some configuration folders were missing. I followed the "Reset Cura" article from the Ultimaker website. I had to delete the configuration folders, then uninstall the program, restart ... then install Cura from scratch. Everything seems to be working fine now.
