When selecting silent fans, keep in mind that they usually have a *much lower* flow rate and cooling capacity. So you might need to provide a lot more or a lot bigger fans.
And indeed, adding rubber dampers, mats, or washers between fan and housing, can greatly reduce transmitted noise and resonant vibrations. Also adding a sound-absorbing mat on the opposite sides of a printer (or room) might help: this does not eliminate the source of course, but it damps the reflections and resonance. Similar to the covering of walls in a sound studio, but then in miniature. If your printer design allows for this, of course, it might not fit everywhere (I don't know the CR10).
1
Smithy 757
I have no specific fan, but NOCTUA has silent fans in all sizes.
hakkattakk 1
I guess it's the fan in the control-box you want to replace? I did this mod: https://www.thingiverse.com/thing:2764990 and used 1200m Noctua fans (NF-S12A) instead. I don't remember if I use any other fans in the box, I guess you can check that in the comments for the mod. However I have used this for over a year now without any problems, and the box seems to be very cool.
I have also replaced the hotend-fan to a NF-A4x20 and added NEMA17 dampers. I must say that the printer is quiet now 🙂
ErenUenal 0
Ok, thanks guys. Sadly Noctua only has 60mm x 25mm fans, but the 120mm fan upgrade seems to be an option. I already upgraded the 40mm fans and added dampers, which made a huge difference, but the fan in the controll box is still very loud.
