Posted · Starting gcode issues
I'm not sure why, but I can't get the starting gcode to work how I want it to.  I simply want to home, preheat the nozzle to 160C, and heat the bed to the desired temp.  However, I feel like I'm telling a toddler to do 5 things and it will do a couple things, out of order.  With the code below, it begins preheating the nozzle to 160, then immediatly mesh bed levels.  It doesn't home and wait nor does it even attempt to heat the bed.
G21 ; set units to millimeters
G90 ; use absolute positioning
M82 ; absolute extrusion mode
G28 ; home
M104 S160 ; Set extruder to 160C
M140 S{material_bed_temperature_layer_0} ; set bed temp
M109 S160 ; Wait for extruder
M190 S{material_bed_temperature_layer_0} ; wait for bed temp
G80 ; Mesh Bed Level
M104 S{material_print_temperature_layer_0} ; set extruder temp
M109 S{material_print_temperature_layer_0} ; wait for extruder temp
G92 E0.0 ; reset extruder distance position
G1 Y-3.0 F1000.0 ; go outside print area
G1 X60.0 E9.0 F1000.0 ; intro line
G1 X100.0 E21.5 F1000.0 ; intro line
M907 E500 ; Set motor current
M221 S{if layer_height<0.075}100{else}95{endif}
Any idea why I'm not getting my desired results?
    That line is not going to work in Cura; Cura has no (and never had) conditional gcode.
    Posted (edited) · Starting gcode issues
    23 hours ago, obewan said:
    What does the generated g code look like after you slice using this start code ?
    seems ok when i test it.
    I ran a test with set M104 S160 and M140 S65 constants as an attempt to remove variables when the first layer variables would have been.  This is what was generated up to the first layer.  It added M104 and M140 values before the start code.  But then the M109 and M190 are completely ignored and the leveling begins
    ;FLAVOR:Marlin
    ;TIME:228
    ;Filament used: 0.104057m
    ;Layer height: 0.2
    ;MINX:113.024
    ;MINY:99.024
    ;MINZ:0.2
    ;MAXX:136.976
    ;MAXY:110.976
    ;MAXZ:15.2
    ;LINEARADVANCEPROCESSED
    ;Generated with Cura_SteamEngine 4.5.0
    M140 S65
    M104 S215
    M82 ;absolute extrusion mode
    M115 U3.8.1 ; tell printer latest fw version
    G28 ; Home
    M104 S160 ; set extruder temp to 160C
    M140 S65 ; set bed temp
    M109 S160 ; wait for extruder temp
    M190 S65 ; wait for bed temp
    G80 ; mesh bed leveling
    M104 S220 ; set extruder temp
    M109 S220 ; wait for extruder temp
    G92 E0
    G92 E0
    G1 F2100 E-0.6
    ;LAYER_COUNT:86
    M900 K30.000000 T0 ;added by LinearAdvanceSettingPlugin
    Edit:  I found the solution to the main problem.  I needed to use G28 W instead of G28, so the bed leveling doesn't occur before the preheat.  Now I'm not sure why I'm getting the couple of lines before the start code.  That is the final mystery that needs to be solved.
    Edited by Th3RadMan
    I have the exact same issue - Cura is inserting both M140 and M104 commands prior to the custom g-code that I have setup, which is to heat the nozzle to 160 and bed to 60 to perform a auto-home followed by a bilinear ABL. This is then followed by heating the nozzle to the layer 0 temp and bed to layer 0 bed temp. How do I get rid of the initial M140 and M104 commands that Cura is inserting?
    Unable to edit my previous post
    figured out the solution: you need to have a "material_bed_temperature" and "material_print_temperature" in your g-code. If you don't, Cura will automatically insert the initial M104 and M140 commands.
