I'm not sure what you mean by helper volume. Could you explain it to me. I searched through all the settings and didn't see anything related.
Thanks Dim3nsioneer
Thanks Dim3nsioneer
Simply use an overlapping "modifier mesh" and select a different extruder for it.
If you don't want to model your own, you can "misuse" the support blocker mesh like shown in this video (just select the other extruder instead of modifying any settings):
Holy shit been looking for this for ages! Thanks!
I'm still struggling with this. I cant seem to select an extruder when selecting the settings to modify for the mesh?
With the modifier block selected just click the other extruder on the bottom left. Don't forget to uncheck "Infill only" in the modifier settings.
I made a quick video of the process:
This technique doesn't work with ver 4.13.1
Can anyone suggest an update please.
I can't get it to work in 4.13.1 either.
It does work in the SmartAvionics fork of Cura. Set the blocker to "cutting mesh" with a wall count, no top or bottom and set it to Extruder 2.
In an oddity - I saved the project in the SmartAvionics Master version and opened it in UM 4.13.1 and it worked. The outer walls were assigned to T1 (Extruder 2).
Works fine for me with a S5 in 4.13.1 (with a deformed model of a cube as modifier mesh). Has any of you guys already tried to clear the Cura installation (deleting/renaming settings folder)?
Dim3nsioneer 559
Yes. Use a helper volume and assign the other extruder to that helper volume.
