gr5 thank you very much for your effort to help.
I know that this would be a solution, but i would like to have solution which is in the normal pipeline.
It is very annoying, if i have to edit the code for one printer while i am working with ten others in the same time. ;-)
gr5 2,333
Well a quick work around is to realize that the bed temp only appears once in the gcode and it's near the top (first 40 or so lines of gcode). So you could set the temp to 197 and then search for that in the gcode and fix it. gcode is pretty easy for humans to read.
I'm not sure where this limit is - it's most likely in one of the json files but there are hundreds of these files.
