Hi, I am facing a problem when i try to print with the second nozzle only , the other nozzle starts working as well even though i specified the color and the parameters to work for the second one only , i'm using cura 4.5
here is the part that i wanted to print and the machine settings.
so what is the problem am i missing something?
Do You have 2 physical nozzles or 1 nozzle with 2 extruder.
if it is 1 nozzle with 2 extruders, you need to check the shared heater box.
in the image you posted you have set the part to use the 2nd extruder( based on color)
if you only want to use the 2nd extruder, you need to make sure that the infill and support etc are set to use extruder 2 as well (by default they are assigned to extruder 1.)
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
HtRabbit 0
