Here. You can clearly see where it retracts every time it goes to the (green) inner wall E8.40884 -> E5.90884
G1 F1320 X96.067 Y75 E8.40884
G1 X96.167 Y75
G1 F2400 E5.90884
G0 F10800 X95.882 Y75
G0 X74.088 Y88.273
G0 X73.818 Y88.543
;TYPE:WALL-INNER
where instead it SHOULD be retracting before the OUTER WALL. Youll notice there is no retraction step from the transition of inner wall to outer wall. Retracting before you go to the inner wall does absolutely nothing to your seam because that's not where your seam is. It's your outer wall that determines your seam, and thats where you want to retract to have perfect seams.
To prove this, I tried setting wall line count to 1. This tricks it into behaving like the expected behavior of wha this setting was meant to do. So that way it would go from infill immediately into outer wall (no inner wall) and it creates absolutely stunning perfect seams. I honestly think whoever wrote this made a mistake and meant to have it retract right before outermost wall.
burtoogle 509
Hi, please attach a project file that illustrates this.
