I have this issue with the latest version, 4.10. I also had this issue in the previous version (4.9.1). It doesn't matter if I change from the profile default of 200 or change it to another setting, as soon as the print job is started, only the bed begins heating. I have to manually set my printer to the desired extruder temp.
Are there any steps I can try to resolve this? I am trying to move to this app and away from the in-house app from the manufacturer. So far, that is really the only issue I have had (outside just needing to pick up more knowledge about it in general). 🙂
I don't mean to hijack, and can submit a bug report if needed. I just wanted to bring it up since I was searching this forum for a solution to this issue. Cheers!
Thank you!
Edited by dmtrotterCouldn't seem to get the older version typed correctly (twice!)
ahoeben 1,850
1. This is a known bug that has been fixed for Cura 4.6
2. This I did not know about, and will look in to.
