tinkergnome 918
14 hours ago, gr5 said:@tinkergnome - any ideas?
Marlin 1.1.x is very different compared to the older versions that are used as the basis for Ultimaker firmware(s). So i can only guess.
"WATCH_BED_TEMP_PERIOD" has something to do with thermal protection, right?
"Paused to use" is not to be found in Marlin sources. But there is "busy: paused for user" - which is a normal "keep alive" message that is sent to the printing host while the printer is performing long-lasting operations.
It's possible to (temporarily) disable "THERMAL_PROTECTION_BED" during the testing period. Just to rule out configuration errors in this area. But don't let it run unattended.
gr5 1,870
