Thanks for the model.
Firstly, ignore the seams shown in the Cura layer view as it doesn't really do spiral mode correctly. It often shows the seam even when the model shows nothing.
I sliced that model using my Cura and I can't see any seam looking at the gcode.
This is the Cura layer view, seam is visible...
And this is the gcode visualised in S3D, seam not visible...
However, it may be that UM Cura doesn't do such a good job as my Cura so you may wish to try one of my releases.
You can find the releases at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
Please read the README.md file there before using.
Got a github source link for that? I do not install random dropbox things on my computer.
The github source links are in the README.md file. You will also need my versions of the cura-build and cura-build-environment repos.
Alternative CURA forks, interesting. I had no idea.
Please push the fix upstream. I am a professional software developer, but in this case I prefer to stay a user.
But it is very nice to see that open source works 🙂
18 minutes ago, bondus said:But it is very nice to see that open source works 🙂
But only after a fashion because a lot of the stuff that I offer to UM gets rejected which is why my fork is now so different from UM Cura.
Poking around in the code I see there is python in there. No wonder that UI is so sluggish and takes random long pauses, just like java but 10 years later.
Yeah, IMHO, using Python for the Cura front end was a big mistake along with Qt/QML.
Printing the same model, different slice, on another printer gives different results.
First printer, Reprap Firmware (Duet3d) shows the seams.
Second printer, klipper, do not show the seams.
It's unclear if it's the GCODE is bad or the interpretation in wrong.
Just like burtoogle showed that the CURA and S3D rendering was different.
burtoogle 506
Could you please attach the model to this thread so I can take a look? Thanks.
