Did you download and try the burtoogle version? That will solve all your problems. I feel like I'm talking but you're not listening. Sorry - it's a little frustrating when I get the same question 10 times and 9 people try my answer and are like "that's amazing" and then the tenth person seems to ignore me.
1) I'm not sure if you know what 25 cubic mm means. It's a volume. If it is a perfect cube then it would be 2.9mm on a side. Is that what you were trying to say? I'm not sure what you mean.
2) So you printed a 25mm cube and then another 25mm cube and one is perfect and one is 25.4? I don't get it.
3) "additional .4mm is my nozzle width" - okay so this is a common thing for people to worry about. If you slice a solid 25mm cube and your line width is 0.4mm, cura is smart - it knows that the lines of filament will stick outside the nozzle by 0.2mm all around so it shrinks all the walls inwards by .2mm which should result in 23.6mm of movement in the gcode and a 24mm cube. The people who wrote cura are pretty damn smart.
Now if your cube is hollow it also steps inward (into the wall) for the inner walls. So if you have a hollow cube with 3mm thick walls, cura knows to attempt to print them thinner than that.
4) So what you see in the third diagram you show? That's fixed in the burtoogle version of cura. The official cura release doesn't do thin walls great. Burtoogle version has some nice fixes for thin walls.
5) What you show in the first photo - Cura can't do that - the way it thinks about inside and outside - it just can't do that. Sorry. People (including me) have been asking for that for about 6 years now. Programmers say it's not going to happen. Some day it will happen but don't hold your breath. Actually there is a mode called "vase mode" that can do what you show in the first photo - but the way you do that is a hack. You first give cura A *solid* model with the inside filled in solid. Than choose vase mode and it will just do one pass around the outer wall just like you want. You have to set the line width to how thick you want the walls and even if you have a 0.4mm nozzle you can do 0.8mm walls if that's what you tell cura to do but cura will do it in one pass.
2
gr5 2,331
@burtoogle?
You probably want to download the burtoogle version - I suspect it will do a somewhat better job or burtoogle might have suggestions but he's probably asleep right now - maybe in a few more hours he can answer you.
geert_2 560
What does it do if you make wall thickness 0.41 or 0.42mm?
When making small text, I make the legs 0.5mm wide instead of 0.4mm, to avoid gaps when the STL might make the walls just a little bit thinner than 0.4mm in corners (and cause gaps), due to the triangles. But I am using an older Cura version, so I don't know how the newer versions handle this.
gr5 2,331
Right - you could set the line width to 0.39 or 0.35 - you can print down to about 0.35 without much (any?) noticable loss in quality. Or up to around 0.6 (but you may need to print slower).
Taco_Bob 1
Well guys, I've been playing around a bit with this and I've found something out.
While doing some other work, I decided to calibrate my printer's axis(es).
I printed a 25 mm³ cube and found that my printer is spot on. But in the X and Y axis, that 25 mm prints at exactly 25.4 mm.
The additional 0.4 mm is my nozzle width. So what Cura does, is it places the center of the line exactly at the wall perimeter of the geometry. So each exterior wall is going to be exactly 0.2 mm (or half the nozzle diameter) beyond the geometry of the model. So when it is, say, a tube, with 0.4 mm wall thickness, Cura is stumped. And when I put that on surface mode, it tries to trace both the outer wall and inner wall, thus drawing two walls instead of one.
See pict. This makes printing engineering parts impractical. I don't know if any other slicer does this. Simplify 3D is too expensive for me, and the others I've looked at have a terrible user interface. Not at all polished like Cura. Cura is much better, but I'll have to adjust all of my models to account for this SOP. Simply scaling a model won't work, since only the outer-most features would be reduced by 0.4 mm, and others would be to a lesser extent.
Maybe in the future there might be an "engineering mode" ? Slicing might take longer due to the extra calculations but I'd use it in a heart beat.
