Suppose you want the first 20 layers to be .2 layer height, and the rest of the print to be 0.3. done. Simple and clean. What so hard to understand? It's a pretty straightforward setting to have. Adaptive layering is straight up not the same you can't compare those two
ahoeben 2,047
Cura already has variable layer height. But apparently, you want manually controllable variable layer height. It helps to be specific in your title.
Edited by ahoebenLink to post
