Good evening and thank you for your response.
The printer is Maker Select v2 using Cura 4.5 with custom printer parameters suggested by the Select v2 manual. I have not printed anything else (of my design) because when I start a print the PLA will not stick to the bed (right now I am only interested in printing my designs). I assume the bed and printer are OK and the bed is level because it prints all samples on the SD card sent with the printer.
When trying anything other than from the sample SD, the Pla seems to be coming out of the nozzle to slow (or the speed too fast). Nine out of ten times the PLA doesnt even attempt to stick to the bed, it just lays on the bed (doesnt stick) or starts to get balled around the extruder after a couple of passes around the print area. The material coming out of the extrder appears to be much smaller in diameter than the sample prints and the PLA appears to be suspended for 10-15mm behind the extruder before it touches the bed. I think the PLA is then cooling off too much before it touches the bed.
My settings are extruder 200, bed 60 degrees. All parameters were default.
I compared the gcodes from the samle print and the Cura custom settings thinking that the extruder was possibly getting raised too high from the bed for the Brim and initial layer but i didnt see that in the gcodes. There is very little difference between the gcodes. . I also tried slowing down the Brim and Initial layer speed (all the way down to 15mm each) thinking it would allow more material per mm to be put on the bed. But that didnt help.
I have used AutoCad for years. Since getting into 3D I started with TinkerCad, then Fusion 360, and now DesignSpark.
My reason for getting into 3D is that i am active in RC airplanes and multi-rotors and its helpful to be able to 3d custom things for the models. For the past couple of years a friend has printed for me but no longer prints. So i tried ordering prints online but being retired I cant afford to do that which brings me to my current dilemma.
I hope you can solve my problem.
Thank you for you response
Roger
Edited by 54Roger
SandervG 1,405
Hi Roger, welcome to the community and thank you for your message.
Which 3D printer did you get to start with? And for what particular reason have you not printed any other models?
Does the 3D printer not work, do you not know how to design in CAD, or do you not know where to find other models?
Thanks!
