Thats what i initially thought. However when trying to attach the base with the fans on again, it wouldnt line up because the heat cartridge was pushing against he metal, indicating it should be going in a little further.
1 hour ago, gr5 said:It sticks out quite a bit - maybe it's normal. If it's in half way then it will probably be fine. It sticks out much more than the sensor (which can potentially go in all the way).
You put the base with the fans on it backwards.
The angled edge faces the front of the printer to hide the heater block visually.
ah silly me, thanks.
gr5 2,069
