Do you think the impact modifier would make a big difference in the radiation length?
We don't need absorber, but a shell to close the detector (PWO crystals).
We want to see the effect of the material in front of the crystals
thanks
regards,
Dim3nsioneer 556
I guess you have access to the data of standard PLA. The impact modifier is probably a trade secret.
What particles do you use? In case you need a neutron absorber, you might want to have a look at AddBor N25 from Addnorth.
If you want to use TPLA as some kind of beam dump you also might want to keep an eye on the deposited energy as PLA has a pretty low heat deflection temperature.
