Posted · Cura trying to print outer walls in mid air (can't use support)
Hi guys, I'm trying to print this object but can't get cura to print it in a different way, it always do the outer circle shell then the inner one and fills up with material in between, but is doing the inner circle in mid air and i cant use support because the lower hole is the same size so it's imposible to remove, also i don't want to deal with support it almost doubles the print time, is there a setting i can change to make this print possible?
