gr5,
Thank You for the advice! I really appreciate it. It was the checkbox. It prints in the center now.
Thank you again!
chaley
- 1
gr5,
Thank you again!
chaley
gr5 2,225
You can position your part far to the side in CAD and cura will ignore that and center your part every time.
If parts aren't defaulting to the center then something is wrong in your printer settings - see "manage printers". Make sure the size of your build area is correct and make sure you have the checkbox correct that sets origin in the corner (not the center - that's only for delta printers).
