For that sorta volume, you definitely wouldn't want to print them one at a time. You could probably make a plate so that 10 get printed at a time but, still, that's 3 long prints a day, 7 days a week..
Also, if you produce 10.000 of the same items 3D printing might not be the best solution.
Yep.
Daid 306
1) 10.000 a year is about 30 a day (7 days a week). Depending on your printing speed/quality you need a few hours per 6x6x6cm model. Using a single printer won't cut it. Also, if you produce 10.000 of the same items 3D printing might not be the best solution.
2) Smooth depends on your model, your calibration, and a few other factors. But I haven't seen perfect smooth yet with my printer. Sanding might work, but melting the outside with a acetone or something also works.
3) 25-30 euro per kg. If you use PLA. However, for medical supplies, you might need medical grade materials, which I don't even know if they exists.
4) Depends on your thread size.
http://www.thingiverse.com/thing:12728
this works. But for "normal" thread, people usually cut in the thread with taps.
