Ah yes I can see it here:
M109 S215
So your start GCODE is telling the nozzle to heat up to 215C. After that, it will be set to the initial layer printing temperature.
If you remove this line, does the problem still occur?
M109 S215
I removed the two lines, and that fixed the issue. I also removed this one:
M140 S55
because according to a page I found that tells the printer to heat the bed to 55°C, and I don't want that, either.
maht 89
Which version are you using?
It's possible you have something in your start gcode that's heating it up to a different temperature. Check your machine settings and look for values something like this:
M109 S180
Why not try using a PLA profile? It has all the settings preconfigured. If you print from recommended mode (e.g. using Cura 4.6), all the ideal settings for PLA are preconfigured.
nasp 1
I'm using 4.6.0.
Thanks! I have this start code in the machine settings:
G28 G1 Z15 F300 M107 G90 M82 M104 S215 M140 S55 G92 E0 M109 S215 M107 G0 X10 Y20 F6000 G1 Z0.8 G1 F300 X180 E40 G1 F1200 Z2 G92 E0 G28
I don't remember having edited any of this; I don't know much about gcode, so I don't touch it directly. Can I just delete the M104 and the M109 lines, or could that break something?
(I'm using the General PLA profile with fine settings. The only thing I changed there was the first layer hight, since that is should be 0.3mm, according to my printer's manual (Geeetech A10).)
Edited by naspLink to post
